> Tranny help from swappers
post Feb 18, 2005 - 7:17 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I finally bought the mr2 lsd tranny. I will be replacing my s54 tranny with my swap. I need to know what 3 motor mounts to use with the mr2 tranny, and what shift linkage for the 6gen swap.
post Feb 19, 2005 - 2:39 AM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
you need the shift linkage thing (not sure what its called) from an alltrac tranny. Not sure which cables though or which mounts.
post Feb 19, 2005 - 4:42 AM
jgreening
Joined Jan 17, '04
From Illinois
GT cables will work (its what I used) Or, ST205 cables would be better. Sphinx has them in his car - you may want to ask him. You can pick up a set for $50 shipped from www.chicoraceworks.com
This post has been edited by jgreening: Feb 19, 2005 - 5:17 AM
post Feb 22, 2005 - 2:34 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
I need to know if you can use alltrac mounts or mr2 motor mounts. They both should be the same right?
post Feb 22, 2005 - 2:44 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
QUOTE(jgreening @ Feb 19, 2005 - 1:42 AM)
[right][snapback]247898[/snapback][/right]
Yeah, i have the ST205 cables. Then fit perfectly.
QUOTE(celica3sgte @ Feb 22, 2005 - 11:34 AM)
[right][snapback]248918[/snapback][/right]
I'm not so sure the MR2 mounts will work. I'm not saying they won't, i've just never seen or heard of anyone using them. I'm using the ST205 mounts. No modification needed, they're a perfect fit.
I have the part #'s for the ST205 mounts and cables at home. If you want, i'll post them up when I get off of work.
post Feb 22, 2005 - 5:37 PM
celica3sgte
Joined Nov 12, '02
From Columbus, Ohio
That's a great idea!!! Please do.
post Feb 23, 2005 - 1:28 AM
sphinx
Joined Apr 10, '03
Ok. Here are the part #'s for the motor mounts, motor mount brackets, and shift linkage / cables from a ST205.
12361-74340.......... Insulator.......... $47.10
12371-74440.......... Insulator.......... $88.00
12372-74500.......... Insulator.......... $109.00
12311-74160.......... Bracket, EN.......... $40.00
12321-74310.......... Bracket, EN.......... $26.00
12325-74230.......... Bracket, EN.......... $53.00
33820-2B350.......... Shift Cables.......... $341.00
I ordered these through Champion Toyota and were all a special order from Japan. Those are the list prices for those items. I didn't pay the list price. Actually, I paid a lot less biggrin.gif Talk to Jeff.
(713)943-7010 Direct Parts Line
I hope this helps. If you have any other questions about swaping the tranny, let me know.
This post has been edited by sphinx: Feb 23, 2005 - 1:33 AM
Lo-Fi Version Time is now: November 29th, 2024 - 12:44 AM
