> Fuel Gauge problem, problem
post Feb 19, 2005 - 12:56 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
OK, so I just bought this 95 Celica GT convertible and I find out that the fuel gauge stops working about halfway through a tank after driving it for sometime. redface.gif redface.gif redface.gif The warranty should cover it but is this fix easy? Also the rear defroster does not work and its not the fuse. An help would be grateful.
For the best designs and screen printing.
WE DON'T PRINT UGLY.
www.TERZink.com
post Feb 19, 2005 - 1:27 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Terzin1 @ Feb 19, 2005 - 5:56 PM)
[right][snapback]247938[/snapback][/right]
The fuel gauge is almost 100% the fuel sending unit. That should be pretty easy to get to and fix/replace. The defroster on the other hand... you gotta test a few things. There should be wires going into a plug that connects to the rear glass... test that for power. Also test the switch on the climate control panel.
post Feb 19, 2005 - 9:28 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
also look at your defroster lines, if a couple are broken it wont work properly. and look at the connections
post Feb 26, 2005 - 8:44 AM
Terzin1
Joined Feb 19, '05
From Indianapolis
ok yea, the terminal where the defroster wire connects to the window is busted off on the left side right at the window. Can i soder it back on? Also, is there any website out there showing how to replace a sending unit?
www.TERZink.com
post Feb 27, 2005 - 1:32 PM
UKcelicaKev
Joined Feb 19, '05
From leicester, England
i ll scan the clinton's manual pages for you and e mail them too you
Gen 6 Celica in Red with VVTI Beams engine, lowered 40mm, front and rear strut braces, asia tec 17 inch alloys, avon ZZ2 tyres, Rage Back box and a decat, JDM rear lights, red bits on the dash and clock shroud and a DVD player.
post Feb 27, 2005 - 1:42 PM
UKcelicaKev
Joined Feb 19, '05
Hi again Ive sent them i hope they are what you need!! and best of luck with it
post Feb 27, 2005 - 6:51 PM
Terzin1
Joined Feb 19, '05
From Indianapolis
thanks for the pages
www.TERZink.com
Lo-Fi Version Time is now: February 22nd, 2025 - 6:05 PM
