IT WORKS!!!!!! custom shifter |
Feb 19, 2005 - 8:18 PM |
Ok, as Some of you know, I did the custom lancer/evo short shifter. When i did it was a lill stiff and hard to shift in gears... worked great but hard. I finally took a look and fixed it. So Its PERFECT! What I had to do was cut two plastic peaces of the assembly for thw shifter linkage on the right to sit down a little lower so it wont bend. It took me like 3 hours today to figure it out and fix it.. but its perfect and well well worth it.
Just thought i would update ya'll that were intrested but skeptical about doing it. |
Feb 19, 2005 - 8:47 PM |
Enthusiast Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
nice work..now only if i had a 5 speed.
Feb 19, 2005 - 9:10 PM |
QUOTE(BLINKYxMUNKEY @ Feb 20, 2005 - 1:47 AM) nice work..now only if i had a 5 speed. [right][snapback]248048[/snapback][/right] that would help. |
Feb 19, 2005 - 10:55 PM |
so its do-able? ill try it maybe.
Feb 20, 2005 - 3:39 AM |
QUOTE(x_itchy_b_x @ Feb 20, 2005 - 3:55 AM) so its do-able? ill try it maybe. [right][snapback]248083[/snapback][/right] Its more then do-able.. its welll worth it.. its awsome .... I love It |
Feb 20, 2005 - 12:31 PM |
Enthusiast Joined Sep 22, '02 From Mammoth CA Currently Offline Reputation: 0 (0%) |
you should write a diy
Feb 21, 2005 - 11:40 AM |
QUOTE(Seth6Gen @ Feb 20, 2005 - 5:31 PM) you should write a diy [right][snapback]248190[/snapback][/right] I wrote one, but its in this link.. http://www.6gc.net/forums/index.php?showtopic=18569&st=60 Its on page 4 scroll down some. I will try to make it better and put it in a good format, also theres an update with two peaces u need to cut. I will post a new pic. |
Feb 22, 2005 - 12:26 AM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
damn, and i just bought a twm...
Feb 22, 2005 - 1:28 PM |
yeah man do it up. take sum new pics ect. id love to try it.
Feb 22, 2005 - 2:42 PM |
Enthusiast Joined Jan 30, '05 From Greencastle, PA Currently Offline Reputation: 9 (100%) |
Do you think the Toyota one is worth the extra cost, or is the feel the same?
-------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 24, 2005 - 3:05 PM |
Enthusiast Joined Dec 15, '04 From newcastle england Currently Offline Reputation: 0 (0%) |
ok,i know a guy who if i take the gear lever out he can cut off "1.5 and re thread the end,"1.5 may be too much but we'll see whe i come to do it,i drove an mr2 with the same mod and it was awsome,i'll get back with the update,over and out,for a while,like tomorrow
Feb 24, 2005 - 3:56 PM |
Is the Evo one a short shift, or a short throw?
Feb 25, 2005 - 1:11 PM |
QUOTE(Supersprynt @ Feb 24, 2005 - 8:56 PM) Is the Evo one a short shift, or a short throw? [right][snapback]249801[/snapback][/right] What do you mean? by shift and throw. |
Feb 26, 2005 - 6:10 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Ok I finally got around to putting mine in( 7th gen celica short shifter off ebay) I didn't have to do any modifications at all to the shifter. Everything fit fine even the spacers that came with the kit. Total with shipping from ebay was $45 if I remember right.
Dindoug is right you do have to cut a piece of plastic out or it will be really stiff. But its easy to do I just took a hacksaw blade and cut it. It took me 5 mins to cut it out. Total install time was about an hour and a half. The tuffest part is getting the big pin out with the washer that holds it in. I took a screw driver pried the washer out and just slid the pin out. The other pin that holds the shifter in you just punch out with a punch. With the 7th gen shifter I didn't have to dremel anything. And I used the original bolts. I did take out the rubber grommets that the bolts slide through, because the spacers that come with the kit replace those. The throw is definatly shorter, and it is crisper. I only took it for a 15 minute test run. |
Feb 26, 2005 - 6:53 PM |
Which shifter did you buy? Does it really matter? Two examples:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...me=STRK:MEWA:IT http://cgi.ebay.com/ebaymotors/ws/eBayISAP...me=STRK:MEWA:IT -------------------- If anyone needs interior stuff, etc, I'm parting whats left of my celi out. Just ask.
Feb 26, 2005 - 7:38 PM |
Enthusiast Joined Oct 29, '03 From Gosport, Hampshire, UK Currently Offline Reputation: 0 (0%) |
Any chance you could show photos of which bits of plastic need to be cut?
Feb 27, 2005 - 4:18 AM |
There is only 1 piece of plastic that needs to be cut, it is underneath the shifter cable after it passes through the shifter housing. You will be able to tell, its the cable that goes to the bottom of the shifter, and when you install it back in the cable rests on that peice of plastic and bends it up a little.
As for which one I bought they are both the same thing, and yea that is what I got. |
Feb 27, 2005 - 9:32 AM |
Enthusiast Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
looks like I'm gana have to get one now.
Feb 27, 2005 - 11:29 AM |
Enthusiast Joined Feb 19, '04 From austin tx Currently Offline Reputation: 1 (100%) |
hmm, i wonder who bought that first one...
Feb 27, 2005 - 6:19 PM |
sounds good, but i got a cool looking ball... an mine was a lil cheaper.. well bout 10 bucks
Lo-Fi Version | Time is now: November 28th, 2024 - 10:30 AM |
