> Which bov, any tips?
post Feb 21, 2005 - 1:36 PM
urbandork
Joined Jul 16, '04
From Los Angeles
What are some tips when looking for a bov? ill be running about 8 to 10 psi tops.
post Feb 21, 2005 - 3:28 PM
Mr_E
Joined Nov 16, '04
From UK
QUOTE(urbandork @ Feb 21, 2005 - 1:36 PM)
[right][snapback]248523[/snapback][/right]
Tips?
Fits on the car. Doesn't leak boost.
If you have a MAF, the ECU might not like you dumping to atmosphere.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
post Feb 21, 2005 - 4:11 PM
Anub1s
Joined Nov 27, '03
Definitely get a recirculating BOV. It helps keep the engine running with a good mixture instead of running to rich for a moment. Bad things can happen that way.
post Feb 21, 2005 - 4:45 PM
urbandork
Joined Jul 16, '04
From Los Angeles
are some companies better then others and what would be an example of a recirculating bov. Im not to fimilar with these things.
post Feb 21, 2005 - 6:42 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(Anub1s @ Feb 21, 2005 - 1:11 PM)
[right][snapback]248555[/snapback][/right]
that "problem" is hyped up alot. looking at the wideband on my car, it doesnt get overly rich.
sure, the bov lets off metered air, but the throttle body is closed. so its not like the air was going into the engine
now if the BOV leaks on a MAS/AFM car, that causes a problem.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Feb 21, 2005 - 8:25 PM
my hks bov is great!
post Feb 21, 2005 - 10:32 PM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
HKS SSQV
Biltz
TurboXS RFL
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Feb 21, 2005 - 10:34 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(SlowCelica94 @ Feb 21, 2005 - 7:32 PM)
HKS SSQV
Biltz
TurboXS RFL
[right][snapback]248679[/snapback][/right]
RFL is crap.
it only works well at full throttle
then it randomly opens at part throttle/boost
its very loud tho, i might put it on my WRX just to see how loud it is at 17psi
post Feb 21, 2005 - 10:37 PM
SlowCelica94
Joined Sep 28, '03
If it's crap, why would you consider using it? That doesn't make sense. I haven't heard any complaints w/ the rfl
post Feb 22, 2005 - 12:13 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE(SlowCelica94 @ Feb 21, 2005 - 7:37 PM)
[right][snapback]248682[/snapback][/right]
i already have it, and i tried it on my car with the stock tmic worked ok then but when i went fmic i noticed the part throttle/boost problem within 2 miles of driving and took it off.
and i gave a reason for trying it
it was to see how loud it would be now with more boost and the volume of a FMIC setup
post Feb 22, 2005 - 9:13 AM
QUOTE(Anub1s @ Feb 21, 2005 - 4:11 PM)
Rich for a moment causes what problems? I've been using my bov open atmosphere for over a year without problems.
SSQV gets my vote. Cant leak.
post Feb 22, 2005 - 9:28 AM
when i heard the SSQV on lagos's car
at ATL HIN
i didn't like it much
its more of a HIGH pitched wistle for an instance then the
pssssst
post Feb 22, 2005 - 9:56 AM
the "sound" of the ssqv is easily adjustable with the interchangable inserts they sell...they go for about 14$ on ebay..im actually thinking about getting the purple insert to have more of a whoosh than the loud whistle, im sure the sound of the silver insert will get old quick..lol
my vote
HKS SSQV
post Feb 22, 2005 - 10:01 AM
I may get an insert also, Idk yet because I do really like the stock sound, but its noice to have a change.
post Feb 22, 2005 - 10:58 AM
nik
Joined Sep 30, '02
greddy type S
post Feb 22, 2005 - 12:43 PM
or you can just take the center piece totally out and just get a pssst. more along the lines of a truck bov.
also the sound will change depending on how you have the screw adjusted.
i have noticed that sometimes my car does bog down a little between shifts and i even get some mild backfire. i think it depends on how large your IC and piping is. Supersprynt, reports no problems with his topmount IC, but i notced mine bog down slightly with the fmic and all the extra piping i have.
post Feb 22, 2005 - 1:11 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i have a cheap "monza" one off ebay. its basicly a turboxs knock off but not the rfl.
it would leak at 10psi so i packed the spring more with washers now its fine. it has a Very large woooosh sound. (like a huge toilet flushing tongue.gif ) hah not that bad.
my friend has the RFL on his 3000gt VR4 its really loud but i was talking to the guy at a local tunning shop and he says the rod inside that BOV is really weak and likes to break. i dont know if thats true or not.
My other friend with a WRX really loves his HKS ssqv. i like it but he didnt hook up the vaccum line to it so when the BOV goes off its more of a lfuttering high pitch whistle. very cool. but i dont know if its that great for the turbo.
If i was going to upgrade id like to get the APEXI dual drive. sounds very nice on the gst i heard it on.
post Feb 22, 2005 - 1:13 PM
Mr_E
Joined Nov 16, '04
From UK
If I was to replace the stock one I'd probably go for a HKS SSQV.
JDM ST205
post Feb 22, 2005 - 8:27 PM
initialdrift55
Joined Sep 23, '03
From Miami,FL
Im with nik the Greddy bov but nik you might want to check out there new one ive heard its bad a$$....guys should look into it its the Greddy type RS
post Feb 22, 2005 - 11:10 PM
i love the wosh type best
Lo-Fi Version Time is now: November 28th, 2024 - 4:31 PM
