turbo not fitting right, oil cooler in the way. |
Feb 21, 2005 - 6:27 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
hey guys i'm right in the middle of installing the ct26 turbo. i have the manifold bolted up and right now the turbo isn't lining up right cuz of the oil cooler line is hitting the turbo's wastegate. did you guys just bend that outta the way or what did you do to get around it?
This post has been edited by rjbibeau: Feb 21, 2005 - 6:27 PM -------------------- |
Feb 21, 2005 - 8:11 PM |
Enthusiast Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
If you take pics we can help you out alot more than trying to explain it. Get some pics up and we'll solve your problem.
Feb 22, 2005 - 8:54 AM |
yea i havent had that problem yet...your gonna have to bend them abit.
13.6@108MPH, 5SFTE Powered |
Feb 22, 2005 - 9:09 AM |
get an oil relocation kit.
Feb 22, 2005 - 9:57 AM |
he's not talking about the filter, super...he's talking about the cooler lines, UNDER the filter..
Feb 22, 2005 - 10:03 AM |
meh.
Feb 22, 2005 - 10:41 AM |
Enthusiast Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
well, if I remember correctly, I just got angry and bent them. I guess that was fine
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Feb 22, 2005 - 1:16 PM |
id be carefull bending those i read that few mr2 guys had that problem and bent them but one cracked and snapped. what i did with my wastegate was cut the rod that goes to the actuator then move the actuator make a custom mount for it so its out of the way. then weld up a new rod that can still work between the two. mine looked really weird had a few 90 degree turns but it worked fine.
Feb 23, 2005 - 2:46 AM |
allright guys thanks for the info i'll take some pics of it but you guys know exactly what i'm talking about. ya i think bending them would work just find just heat em up a lil bit and give em some bendage.
Feb 23, 2005 - 8:12 AM |
before you bend them there are 2 little brackets that support the pipes, one on the front of the block, under the oil sender, and another on hte side, beneath the dizzy, remove them and it will move much easier.
Feb 23, 2005 - 2:53 PM |
ya i remember seeing those brackets thanx for the tip. i probable won't be able to use em again unless i fab up a special bracket for it.
Feb 25, 2005 - 5:06 PM |
what the smack is a dizzy
Feb 25, 2005 - 6:53 PM |
dizzy = distributor
Feb 26, 2005 - 11:55 AM |
ahh why is it referred to as that?
Feb 26, 2005 - 12:48 PM |
its just slang..lol
Lo-Fi Version | Time is now: November 28th, 2024 - 3:07 AM |
