> Race clutch, noise common?
post Feb 26, 2005 - 12:04 AM
Dacoolguychris
Joined Jan 5, '05
From Santa Ana, OC So Cali
I've been researching this and haven't found a concrete answer..
I just got a 6 puck ACT racing clutch put in my car.. I hear a little whistle/grinding noise when shifting into first and sometimes into second..
I've read some sites that say this is common with racing clutches.. is this true.. or is there something wrong with my clutch setup?.. let me know..
knew to me and didn't start making the noise til i had the clutch installed.. wondering if maybe they screwed up installing into my car
-Chris
post Feb 26, 2005 - 9:44 AM
maikl
Joined Mar 3, '03
From cyprus
this is very common on hondas most of my friend's have noise maiking clutch's....... i don't know what the reason is but i thing you have nothing to worry about........ but check it with an mechanic just in case.......
post Feb 26, 2005 - 12:24 PM
You got a racing clutch because...you have something other than 5s?
post Feb 26, 2005 - 2:10 PM
Dacoolguychris
Joined Jan 5, '05
no i got a race clutch because i wanted something with more grip than stock was for me.. and the price diff was only 40 bucks.. and the pads etc will last longer than if i got a OEM clutch..
also i'll be ready for incase i wanna get something else besides a 5s...
sorry just been attacked soo many times from people who have never tried out a racing clutch.. talking how on a stock engine there is no diff.. but i have noticed a big difference.. i can chirp all the way through third gear.. unlike before with the OEM clutch..
yeah i've read that in hondas this happens too.. and only through the first two gears.. but when the clutch finally grabs in thrid it stop making the noise...
fine with me.... just was hoping it wasn't a problem..
-Chris
post Feb 26, 2005 - 9:23 PM
you may want to take it back to the place that did the install. clutch rattle normally happens when you dont have your clutch adjusted correctly, the pressure plate wasnt cleaned correctly, throw out bearing making noise, etc.
if you paid money for the install... take it back to them and see what they have to say about it.
post Feb 26, 2005 - 10:51 PM
If the difference was only 40 bucks doesnt sound like a race clutch, just sounds like its a stage1 upgrade. Is that what it is?
post Feb 26, 2005 - 11:13 PM
Beams
Joined Jul 29, '03
From Cyprus
Yes the sound is normal, i have an ACT installed on my celica, don't worry about it, just don't push it too hard....drive normally for a couple of hundred miles. The clutch in the beginning makes much more noise...it will settle though and the sound won't be as loud after a while. Good buy man, enjoy the cluth wink.gif
post Feb 27, 2005 - 2:17 PM
Dacoolguychris
Joined Jan 5, '05
I bought a ACT 6 puck clutch.. friends of mine.. on a strip of car shops.. so they all buy parts from each other really cheap.. that's why it oly cost me a diff of 40 bucks for the racing clutch... about $180 for the race clutch...
performance clutch.. etc.. love it.. and now with my new CAI sounds like i've got some power finally
-Chris (nezt up is the install of a magnaflow exhaust smile.gif)
This post has been edited by Dacoolguychris: Feb 27, 2005 - 2:17 PM
post Feb 27, 2005 - 2:42 PM
1bwilson
Joined Aug 30, '02
From Maryland
Ive had a ACt for years now and it doesn't make a sound.
Chirping 3rd will go away with time, well almost away.
Member of Team 5sfTe
post Mar 3, 2005 - 6:42 PM
nitemare
Joined Jan 12, '03
I bought an act clutch stage 1, about two years ago. Never a sound. Works so much better than stock., and about $100 cheaper! Toyota stock parts are such a ripoff! anyways...might want to check it out.,..
post Mar 3, 2005 - 8:03 PM
you didnt mention how long you have had the clutch for. if u just got it installed, wait about 500-1,000 miles for it to break in correctly.
post Mar 3, 2005 - 8:21 PM
spunky393
Joined Apr 22, '04
From illinois
my act racing clutch doesn't make noice
post Mar 6, 2005 - 9:26 AM
Alan
Joined Jan 23, '05
From Malta
I was gonna buy the act clutch for my celica but I am hearing to many bad comments about it, my friends clutch didnt produce enough actuation and he just put it in the bin and bought a TRD clutch sorrry about the bad news
post Mar 6, 2005 - 11:29 AM
Beams
Joined Jul 29, '03
From Cyprus
No one mentioned anything negative about the ACT clutch, some people experience noise which they say is common on their cars, i have a friend who owns a civic type-r and has ACT installed and makes noise when releasing the clutch after engagin first gear. And as a matter of fact the clutch bites so hard when i upshift from 1st to 2nd the car jumps like a maniac. Don't want to brag or anything, just making a point that i've had my ACT for about 3 months and i am perfectly happy. Anyway not meaning to lash out or anything but a lot of things are explained in this article, you might find it helpful since loads of positive points are pointed out and explained about the ACT Clutch. Enjoy.
http://www.turbomagazine.com/tech/0407tur_clutch/
Lo-Fi Version Time is now: November 28th, 2024 - 5:46 AM
