help with front shock install, help!!! |
Feb 26, 2005 - 11:11 PM |
Has anyone else put o bilsteins? Im trying to replace fronts for now but I got the shock and not the whole shock absorber, how can i replace shock in stock shock? so far i tried taking the cap off the stock, then theres 4 bent over pieces keeping stock one in place, should i unbend them or screw it?
"to put in the strut inserts, but they were crimped in and WOULD NOT come out." is there a way to get around this???? This post has been edited by LewFX: Feb 27, 2005 - 1:08 AM -------------------- |
Feb 27, 2005 - 4:34 AM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
i dont understand. i just put in tien shocks, used the how-to, and had not problems. Can you be a bit more specific?
This post has been edited by CheesyLobster: Feb 27, 2005 - 4:59 AM |
Feb 27, 2005 - 9:56 AM |
Enthusiast Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
un krimp them i guess, I alwasy just get the whole thing, rather then just the insert because its not something I wana mess with.
edit: cut the krimped part off with a grinder and crimp a new section after its in This post has been edited by creis: Feb 27, 2005 - 9:59 AM -------------------- |
Feb 27, 2005 - 1:26 PM |
i just ran into the same problem. it turns out that 98-99 uses "sports" suspension. meaning that you cant just replace the inserts cause they are sealed. you are going to need a whole new strut.
Feb 27, 2005 - 1:30 PM |
son of a biatch!!!!! do the new ones at least have the turn off ones so i can replace the shock inside?
This post has been edited by LewFX: Feb 27, 2005 - 1:36 PM -------------------- |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:34 PM |
