> Intake Temp Sensor
post Feb 27, 2005 - 3:03 AM
tomazws
Joined Oct 30, '04
From So Cal
When I was uninstalling the air filter box, there's this lil plug that you could just pull out. That's the temp sensor right?
What will happen if I forgot to drill a hole on my cold air intake to shove this sensor thru the tube?
Many thanks!
post Feb 27, 2005 - 4:20 AM
Anub1s
Joined Nov 27, '03
Your car will run right? biggrin.gif When I had my Celica I put in a cold air intake and drilled the whole for it and just used some silicone goop to hold it in.
This post has been edited by Anub1s: Feb 27, 2005 - 4:21 AM
post Feb 27, 2005 - 4:27 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
Yep, thats the thermometer. You definately need it for your car to run efficiently. Just drill a hole in your CAI (I think I used 1/2 inch?) Just don't make the hole to big or it will move around. To hold it in place, use the little rubber thing that was holding it in place on the stock airbox.
post Feb 27, 2005 - 12:16 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
oh god i just relized when i put in my short ram in I left my temp sensor just hanging in my engine bay for the past 4 months or so...did this hurt anything? lol...woops!
post Feb 27, 2005 - 12:37 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(pimped6gen @ Feb 27, 2005 - 5:16 PM)
[right][snapback]250750[/snapback][/right]
it doesn't really hurt anything... your fuel maps would just not be as accurate...
post Feb 27, 2005 - 1:27 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
QUOTE(Kwanza26 @ Feb 27, 2005 - 5:37 PM)
[right][snapback]250754[/snapback][/right]
so my it will hurt my mpg? or what?
post Feb 27, 2005 - 1:35 PM
urbandork
Joined Jul 16, '04
From Los Angeles
To clear things up....
If you leave ur temp sensor just hanging under the hood. It will actually be reading hotter air then it would if it was in the stock air box. This sends rong data to the cars comps and i believe less fuel to the cylinders.
Basically while your intaking cold air (short rams not included) you comp is being told that its actually intaking WAYY hotter air. This is bad and in a sence defeats the whole idea of CAI.
Best solution is drill a whole and use the rubber peice thats on the stock airbox to hold the senor in the pipes.
If you look at teh CAI how to there are pix.
Another thing to note are those little resistors ppl sell on ebay promissing HP gains. What this does is trick ur engine into thinking its getting really cold air and thus thow more feul into the cylinders. While this isnt the best thing for the car it does show the importance of having the temp sensor actually sensoring the air that goes into the engine rather then WAY hot air thats in the engine bay.
post Feb 27, 2005 - 3:52 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
wow thanks for the replies guy BUT...
what if i had the sensor down under the filter so its actually sensing colder air while i am driving...that may be why my tempertue on the gauges read just a little bit above the C on the gauge....could this be a VERY cheap way to get "cold air"??? or is the not good?
post Feb 27, 2005 - 4:39 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The ecu doesn't rely completely on that sensor to calculate fuel maps... so its effects aren't major. The only time it can adversely affect the ecu, is when the sensor dies or is jumped (like those ebay power chips)...
post Feb 27, 2005 - 4:48 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
I see so my temperture gauge whithin my car does not 100 percent rely on that sensor? so then is there another reason why when i am driving my temperature guage goes down to almost the C and when i am stopped for long periods of time it goes up about half way?
This post has been edited by pimped6gen: Feb 27, 2005 - 4:49 PM
post Feb 27, 2005 - 5:00 PM
mikew04
Joined Feb 19, '04
From austin tx
The temp guage measures coolant tempurature.
post Feb 27, 2005 - 5:03 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(pimped6gen @ Feb 27, 2005 - 9:48 PM)
[right][snapback]250827[/snapback][/right]
The temp gauge in your car is measured from the Coolant Temp Sensor... not the intake air temp sensor.
post Feb 27, 2005 - 5:04 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
QUOTE(mikew04 @ Feb 27, 2005 - 10:00 PM)
[right][snapback]250831[/snapback][/right]
so check my coolant levels?...so i am confused...please tell me if i am right or wrong..i am trying to understan this, the sensor that goes into my intake has nothing to do with the temp gauge in my car....its only there to let the ecu know what tempurature air is entering into my intake?
This post has been edited by pimped6gen: Feb 27, 2005 - 5:05 PM
post Feb 27, 2005 - 5:24 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(pimped6gen @ Feb 27, 2005 - 10:04 PM)
[right][snapback]250833[/snapback][/right]
Yes...
post Feb 27, 2005 - 5:41 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
ok now that we got that all cleared up...i was wondering why my guage in my car is right above the C when i am driving but sometimes it just randomly goes up about half way while i am driving....and when i am stopped it ALWAYS goes up to half way...is tthere something wrong w/ my coolant? or is there something else that could be the problem?
post Feb 27, 2005 - 11:12 PM
urbandork
Joined Jul 16, '04
From Los Angeles
sticky thermostat?? what do you guys think??
Is ur fan going on?
are ur collant levels good?
just shottin ideas out?
post Feb 27, 2005 - 11:28 PM
pimped6gen
Joined Sep 16, '04
From Hershey, PA
thanks urbandork I can check on those possibilities!
Any more things that could be wrong?
post Feb 28, 2005 - 12:42 AM
urbandork
Joined Jul 16, '04
From Los Angeles
This makes me wonder. My operating temp puts the needle on the temp gauge at its half way point. Is this normal or should i be worried? i think its normal right?
post Feb 28, 2005 - 3:47 PM
mikew04
Joined Feb 19, '04
From austin tx
yah, thats where it should be
post Feb 28, 2005 - 4:07 PM
tomazws
Joined Oct 30, '04
From So Cal
I've drilled a hole and plugged that thing in...
Damn, that's a huge hole. I neeed to buy more drills..
Lo-Fi Version Time is now: February 21st, 2025 - 11:48 AM
