> Headers of 5S-FE, Not Stupid post, read
post Feb 28, 2005 - 1:06 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
http://www.hotshot.com/main.htm
There's a link to the hotshot headers for the 5S-FE. I'm not sure if this is the same company that is making headers for that big group buy or not. Either way, here's some info on it.
EDIT: Checked it, it's definately not the same as the group buy one. But this one is $457. This one seems to be from a lot more creditable place though. Bad thing is its for the 90-93 5S-FE, but it should fit with/without mild mods. Correct me if I'm wrong.
This post has been edited by Bigmeanbulldog55: Feb 28, 2005 - 1:09 AM
Live Free, Be Happy
post Feb 28, 2005 - 5:15 AM
94Toy
Joined Apr 3, '03
From Omaha, Ne
It says that is fits all 2.2 celica's but are there slight diferences in the design of the 5th gen header compared to the 6th gen?
This post has been edited by 94Toy: Feb 28, 2005 - 5:15 AM
post Feb 28, 2005 - 12:26 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(94Toy @ Feb 28, 2005 - 5:15 AM)
[right][snapback]251189[/snapback][/right]
I'm sure there are any differances. Cause the engines can be swapped easy. And I had a 90GT and it looked exactly the same. But you can't see everything, I guess there could be miner differences. All in all though, this looks to be a good qualitly header. The 4 into 2 into 1 shows that they actually put thought into it, and didn't just make a new exhaust manifold.
Live Free, Be Happy
post Feb 28, 2005 - 12:56 PM
liquor
Joined Jan 31, '03
From Montreal, Canada
Nice! but 460 bucks...thats alot of money for a header!!!
post Feb 28, 2005 - 1:06 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
They don't have a Dyno! OMG this is maddness lol.
post Feb 28, 2005 - 2:45 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
I called them and they said the dyno results will be posted in a cuple days. They said they've done them, they just haven't got them in yet. If I get a header, this will more than likely be my root. They may cost more, but they seem quality, and thats very important to me.
Live Free, Be Happy
post Feb 28, 2005 - 2:46 PM
erics1one
Joined Aug 27, '04
Sweet. Make sure you post some numbers here, if they don't plan on doing so.
post Feb 28, 2005 - 10:02 PM
spunky393
Joined Apr 22, '04
From illinois
I've explained this numerous of time in numerous post. The way the 90-93 5s-fe engine sits in the celica, and then the 5s-fe that sits in the mr2 are flat. No degree, meaning, when if you buy a header for the engine, but it's made for the mr2 or the 5th gen celica, it won't work. You would have to completely bend pipes the wrong way, and it would OF COURSE effect the outcome of the headers, may even be worst than what we got now.
post Feb 28, 2005 - 10:30 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(spunky393 @ Mar 1, 2005 - 3:02 AM)
[right][snapback]251491[/snapback][/right]
I disagree with that... The only modifications will be done after the runners... after or at the collector. This should not affect how the exhaust gasses are pulsed and should not affect performance to any major degree... and to make an aftermarket header worst than stock... that's gonna be very hard, considering the stocker uses small runners and has a built-in cat... ;]
post Feb 28, 2005 - 10:52 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Kwanza26 @ Feb 28, 2005 - 10:30 PM)
[right][snapback]251506[/snapback][/right]
First off. Kwansa is right, the only mods would be the the downpipe. I've reseached this extinsively.
Second, that being settalled, this header is for the 2.2 liter celica. Didn't you check the link? The only difference is for ours is it is a 90-93 header. As I have explained in my previous posts, I don't think this will be a problem.
Third, if I don't get this header, I'm getting one for an mr2 and putting on my car just to prove that it's possable and not that hard. And the chances of that being done are more than me buying the celica header.
EDIT: Nice car there spunky. I like the real clean white cars. Makes me want to go out and buy some OEM skirts real bad.
This post has been edited by Bigmeanbulldog55: Feb 28, 2005 - 11:48 PM
Live Free, Be Happy
post Mar 1, 2005 - 11:51 PM
spunky393
Joined Apr 22, '04
From illinois
QUOTE(Bigmeanbulldog55 @ Feb 28, 2005 - 10:52 PM)
[right][snapback]251512[/snapback][/right]
HAHA, thanks! But what i meant, the difference between the celica, is if you put a header made for the 90-93 of mr2 on a 94-99 celica (all three 5s-fe 2.2L engine), the end of the header will be pointing at the ground.
post Mar 3, 2005 - 11:52 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Still no dyno's being posted on the site. I'm going to call tomorrow and harrass them about it.
Live Free, Be Happy
post Mar 4, 2005 - 12:20 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(Bigmeanbulldog55 @ Mar 4, 2005 - 4:52 AM)
[right][snapback]253017[/snapback][/right]
Dyno, dyno, dyno! Thats alot of money, and i would like to see an independent dyno test, even if I got to chip in to pay for it. 2-3 hp increase does not work for me, and its possible to buy a header with less hp then stock. It would also be hard to trust the companys dyno test. They can put any number in there. i remember reading a magazines report on dyno on headers, and they were so off from what the companys dyno said. Some were worse then stock! I know all dynos are different though. Somebody buys one, Ill chip in for a dyno test.
This post has been edited by madmods: Mar 4, 2005 - 12:22 AM
post Mar 4, 2005 - 2:03 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(spunky393 @ Mar 2, 2005 - 4:51 AM)
[right][snapback]251984[/snapback][/right]
I've explained many times also... only slight modification to the collector/downpipe is neccesary to fix that problem. The only way your argument would hold water, is if the blocks are physically different, but they are NOT. The exhaust manifold will bolt up the same way no matter what direction the engine is facing, tilting, sitting, floating, standing, you name it. Let me remind you, the engine does not bend. The ONLY part that points to the ground, is the downpipe... and that can be correct with about 30.00 worth of work from any decent exhaust shop. Because the modification is AFTER the collector, there will be NO affect to how the exhaust gases flow from the runners. You keep saying the same thing, yet you've never tried to explain anything. The engines are the essentially the SAME.
post Mar 4, 2005 - 12:20 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
There's no point in arguing on the matter. Kwanza is right it can work with easy mods, but madmods is right too, it will point at the ground without mods. I'm going to put this header on my car to dispose of this argument once and for all.
Live Free, Be Happy
post Mar 10, 2005 - 4:33 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Hotshot has now said that these headers will fit all 5S-FE Celicas. I'm still wating on dyno numbers from them, and cheaper prices.
This post has been edited by Bigmeanbulldog55: Mar 10, 2005 - 8:01 PM
Live Free, Be Happy
post Mar 11, 2005 - 2:14 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
We should all chip in for a dyno test on the header vs stock. It would be worth it for all of us.
post Mar 11, 2005 - 10:39 AM
shin
Joined Aug 21, '04
From New York City
i wouldn't mind chipping in. i'm dying to get a header for my ride...
~*MuH NeW RiDe*~
post Mar 11, 2005 - 5:54 PM
spunky393
Joined Apr 22, '04
From illinois
Hotshot's company pulled all this same BS on me about year to two years ago. Saying the exact same things you are relaying. As a 6th gen Celica comunity, any dealer could really give a bigger ****, they don't CARE.
post Mar 21, 2005 - 10:27 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Good news everyone. Hotshot emailed me back and said that they'd like to have a celica dyno'd with the new header, but they don't have a stock GT. The one that they checked it on was modified already. They asked me if anyone in the L.A. area from this site would like to volinteer their car for the test. Anyone who want's to, post message.
Live Free, Be Happy
Lo-Fi Version Time is now: November 27th, 2024 - 6:46 PM
