> HAVIng hard time startin my car in the cold, need help
post Mar 1, 2005 - 8:21 AM
XxAxnCelica95xX
Joined Dec 28, '04
From New Jersey
well my car not startin lik it should in the cold...when it warm it start rite up..its weird..i change the battery..sparkplugs...do anybody know wat is goin on...it wont start in the mornin..lik today and day b4 and so on....i hav to start it sever time in order for it to starts... confused.gif
As the time goes by
My life change...
I hope i wont change
Nor my heart
but it is broken..wat can i do..
IT life...I hate it...but i lov my creation
post Mar 1, 2005 - 8:28 AM
TrD3sgte94
Joined Dec 4, '04
From just moved from houston to austin
check ur alternator w/ a volt meter to see if it might be going out
-wes-
(thats how mine happened)
[SIZE=7][COLOR=blue][SIZE=1]-WES-
post Mar 1, 2005 - 10:37 AM
check your cold start injector time switch. my car would have a hard time starting cold too. turned out that the harness plug had cracked and wasnt making good contact. fixed the plug with crazy glue and now it starts right up.
post Mar 1, 2005 - 12:31 PM
macavely
Joined Nov 4, '02
join the club ...my car doesnt start either.... i check air and spark its all good ... now i have to find to see where i'm not getting fuel.... i think lagos might have it..it could be a CSI problme... boy i'm going to have fun getting to it..
post Mar 2, 2005 - 7:18 PM
liquor
Joined Jan 31, '03
From Montreal, Canada
what do you mean by COLD? below 0 degree fahrenheit? In winter in the morning its almost always below 0 where I live and i neved had problems but make sure:
- at least 1/4 fuel
- close all eletric devices before you start
This post has been edited by liquor: Mar 2, 2005 - 7:18 PM
post Mar 2, 2005 - 8:58 PM
mac, its located right next to your oil pressure sender and water temp senor. rembmer, this is the time switch im talking about, not the injector. its really easy to get to on the 3s and should be the same on the 5sfe.
post Mar 4, 2005 - 2:07 PM
BlackSTX
Joined May 17, '03
From Florence, KY
You should make sure you use 5W30 in the winter instead of 10W30. Straight out of the owner's manual.
Lo-Fi Version Time is now: February 21st, 2025 - 12:40 PM
