> turbo coolant and oil lines, Pix? pointers
post Mar 2, 2005 - 8:20 PM
urbandork
Joined Jul 16, '04
From Los Angeles
As you probably have already figured i am doing a 5sfte. Ive read the how to as well as a bunch of other articles about this stuff. But im still a little confused as to where the coolant and oil lines run to and from.
I looked at the engine bay and kinda have idea but not to sure.
for the oil line the to the turbo id be getting my oil from a 3sgte pan but where would i return it to. Ive heard of ppl dumping into the dip stick? whats the best place to run the return as well as the best size for tubes. (for the size i searched and found the article outlining it but ppl seem to disagree with eachother as to what specific size to run on the to and from lines)
For the coolant lines im a bit confused.
Pix are welcomed as im a more visual person.
thanks in advanced.
post Mar 3, 2005 - 12:17 AM
urbandork
Joined Jul 16, '04
From Los Angeles
pix??? bump lol
post Mar 3, 2005 - 1:59 AM
FallenHero
Joined Dec 26, '02
From Alabama
Well, I don't know how most people do the coolant, but if the turbo is water cooled, I would run a closed loop cooling system. I drew this up a Long time ago. wink.gif
Basically, have a reservoir for the coolant. Preferably something that can take higher temperatures. Buy a electronic water pump (Ebay) for fairly cheap and run a switch to the cab to cut it on and off. If you get the proper pump you can run it at full speed all the time and keep the turbo nice and cool. So, you run the coolant line from the pump to the turbo. Here is the tricky part. wink.gif Buy a heavy duty oil cooler and run the coolant line to it (think of it as a tiny radiator for the closed loop water system) from there run the line From the tiny radiator either to a catch can and then back to the reservoir, or straight back to the reservoir.
Wham, you have decreased the running temperature of your turbo, and increased it's life. wink.gif
post Mar 3, 2005 - 2:31 AM
urbandork
Joined Jul 16, '04
From Los Angeles
Perhaps later when i have more cash but for now ill be getting the collant from the car.
n e one have n e pix. if n e thing ill jsut snap some pix at the next meet.
post Mar 3, 2005 - 9:42 AM
1bwilson
Joined Aug 30, '02
From Maryland
There are 3 hoses under the Tb that run coolent. The 2 ones to the right are both cool ones i think.
Member of Team 5sfTe
post Mar 3, 2005 - 1:27 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright to get the oil to the turbo do not use the pan cuz it's gonna be dirty oil. take it either from the oil sender with a t fitting it requires a 1/8" bspt thread adapter. I'm going to be running a sperate line from there over to the fender well or something just so that the fitting doesn't snap off becuase a few mr2 guys have had that proble. i spent over 250 bucks on the aeroquip fittings. and for the return line i just took my stock oil pan off by dropping the crossmember and drilling out a 1" hole and putting a -12AN bulkhead fitting on it. and for the oil feed line use a -3AN line if your gonna go the stainless braided way. or you can use an oil filter plate which you than can draw the oil from there. i'm gonna be using the sender option just cuz i have heard of the oil plates leaking. as far as the coolant goes i is easier to retrieve it from the oil cooler. there are two hose right there if you take of the manifold and the heatshield. i'm pretty much finished with my project i just have to get some odds n ends like bolts and ect and waiting for the fuel pump to arrive. i've spent a lot of time on this about 2 years collecting all of the parts and having patience until i get more money. any more questions just holla. ohh btw the turbo's wastegate is gonna hit the oil cooler lines when your try to bolt it up. just heat up the line and bend it with a 2x4 and a hammer just give it a few taps and it will clear it.
This post has been edited by rjbibeau: Mar 3, 2005 - 1:30 PM
Lo-Fi Version Time is now: January 12th, 2025 - 2:50 AM
