> Wingless, how much would it cost
post Mar 3, 2005 - 10:28 AM
dretti
Joined Jun 5, '03
From West Chester
how much do you guys think it would cost to remove my stock 3 post wing and fill in the holes?
post Mar 3, 2005 - 11:03 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
depends which way you wanna go.
you could Remove it by yourself. Then use body filler for the holes then some nail polish or matching paint or touch up paint.
Or spend prolly around $100 for someone at a body shop to do the same.
post Mar 3, 2005 - 12:20 PM
i used body filler on my 3 post when i toook it off
then when it got painted
i think i spent 50$ of that having it welded shut
i'm getting cf and don't need it
This post has been edited by playr158: Mar 3, 2005 - 12:21 PM
post Mar 4, 2005 - 12:26 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Do you have boom in your trunk. I shaved a third light from z24 vert once, and I didn't weld a plate(used fiberglass), then i used filler.......2 12"subs eventually cracked my paint frown.gif
A welder will do it for a 12 pack, just grind down the welds yourself, and a little bit of filler
post Mar 4, 2005 - 1:59 AM
dretti
Joined Jun 5, '03
From West Chester
thanks for your help guys. at the prices you guys mentioned it sounds like i will be wingless soon.
post Mar 4, 2005 - 11:13 AM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
i looked around when i had TRD to see if i wanted TRD installed or be spoilerless
Lo-Fi Version Time is now: December 2nd, 2024 - 10:20 AM
