Rubber trim around headlights, Its falling off, what can I do |
Mar 3, 2005 - 10:11 PM |
Enthusiast Joined Jul 8, '04 From Durham, NC Currently Offline Reputation: 6 (100%) |
Hi,
I was just wondering what I could do about my headlights. There is a black rubber trim that goes around all of them, and they seem to be coming off.. Would ordering replacement trim fix this?? The trim does not appear to be broken, its just loose so I always push it back in a bit... Thanks, Rob -------------------- |
Mar 3, 2005 - 10:17 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
they just do that. if it really bothers you, you can take off your front bumper and adjust the clips that hold it on. although they will eventually come loose again anyway
Mar 3, 2005 - 10:20 PM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
or superglue them and forget about it.
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
QUOTE(Drocay @ Mar 3, 2005 - 10:20 PM) or superglue them and forget about it. [right][snapback]252961[/snapback][/right] Until you have to replace a headlight. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 3, 2005 - 10:23 PM |
you talking about the rubber around the headlight? mine started coming off too, used super glue and it worked perfectly.
Mar 3, 2005 - 10:27 PM |
Thanks guys that was fast .. Um I'm not sure if I want to superglue it.. What if I replace the headlight like jgreening said... Will I have to order a new one? (the rubber piecet that is..)
I'm glad to know that it's a common problem, I thought it was maybe cause my cars 11 years old.. -Rob This post has been edited by RbrtNdrws: Mar 3, 2005 - 10:29 PM -------------------- |
Mar 3, 2005 - 10:30 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
superglue it. on the RARE event that you need a new headlight (which is very unlikely unless you are in a wreck, in which case you'll probably need a new seal anyway...), the trim is only 8 bucks. i had to order some for my high-beams not long ago.
-John- -------------------- |
Mar 3, 2005 - 10:50 PM |
Enthusiast Joined Nov 1, '04 Currently Offline Reputation: 1 (100%) |
same thing is going on with me...
but its only my one rubber thing... My other one fell off I needs to get more -------------------- 2003 Nissan Murano SE |
Mar 4, 2005 - 12:10 AM |
Enthusiast Joined Jan 24, '05 From toronto,ontario canada Currently Offline Reputation: 0 (0%) |
Happened to me to, i just carefully put it back and did what the other ppl did
-------------------- Go leafs go
Mar 4, 2005 - 12:45 AM |
Enthusiast Joined Nov 24, '04 From Moscow, russia Currently Offline Reputation: 0 (0%) |
i used a rubberized glue......
holds it in place, but you can get the rubber rings off if ever you want with a sharp blade !!!!! -------------------- Life is for living, and you don't get a second chance Take care now !! |
Mar 4, 2005 - 1:26 AM |
Enthusiast Joined Oct 28, '02 From Europe, Lithuania Currently Offline Reputation: 8 (100%) |
Nope, they will remove easily if you use superglue, i useed it, and still removed myne easy (ruber surounding) Superglue wount stick to glass too hard, but it will help to hold the surounding in place.
QUOTE(jgreening @ Mar 3, 2005 - 8:20 PM) QUOTE(Drocay @ Mar 3, 2005 - 10:20 PM) or superglue them and forget about it. [right][snapback]252961[/snapback][/right] Until you have to replace a headlight. [right][snapback]252963[/snapback][/right] -------------------- Ex celica owner - just a guy from other side of the pond...
Full custom Projects from restoration to performance builds <<<<<< DCw / JDMart >>>>>>> |
Mar 4, 2005 - 2:57 AM |
Enthusiast Joined Oct 9, '02 From San Diego, CA Currently Offline Reputation: 0 (0%) |
heh am I the only one that just ripped mine off when they started coming loose? I think they look good w/o them... well I still have the two inner ones on just not the two outer headlights (low beams)
Mar 4, 2005 - 3:55 AM |
Enthusiast Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) |
Just leave them off, I dont have any on my`n, looks cleaner without them.
Mar 4, 2005 - 4:53 AM |
QUOTE(Benevolence @ Mar 3, 2005 - 11:57 PM) heh am I the only one that just ripped mine off when they started coming loose? I think they look good w/o them... well I still have the two inner ones on just not the two outer headlights (low beams) [right][snapback]253100[/snapback][/right] Amy(amysmojo) also doesn't have them on her car. I glued mine on using spray on 3M glue, and it's worked perfectly for me. -------------------- New Toyota project coming soon...
Mar 4, 2005 - 8:38 AM |
goop glue
Mar 4, 2005 - 9:46 AM |
Enthusiast Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) |
i have the same problem...
Mar 4, 2005 - 1:07 PM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
rubber glue gun thats what i used and it hasnt popped up to bother me since
-------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Mar 4, 2005 - 2:29 PM |
Enthusiast Joined Dec 3, '04 From torrance, ca Currently Offline Reputation: 0 (0%) |
if your missing the metal clip that holds the ring in place just get a flexible piece of metal and bend it in the same way and it holds it in place, well at least for me
Mar 4, 2005 - 3:34 PM |
thanks guys, I'll try supergluing it..
Also, Coomer I sent you a PM but I dont know if you received it.. I had a question about something. -Rob -------------------- |
Mar 4, 2005 - 3:44 PM |
Mine come loose every so offten, every time i park and notice ther coming out, i just tell them whos boss and push them back in.. lmao.. its true..
Lo-Fi Version | Time is now: December 12th, 2024 - 2:50 PM |
