> shaking steering wheel
post Dec 2, 2002 - 9:57 PM
jumpinccv
Joined Nov 11, '02
From Ohio
i dont know if this right forum but just a little question. Ive had my celica since june, but about two months after i started noticing a little shaking in the steering wheel. I had the fronts balanced and the rest of the stuff checked. It was a little better for a awhile. Then it came back. so anyway i had to rotate my tires, did that and it helped a lot for like two weeks. now it starting to come back again, its better sometimes and worse others. And not always on rough road and smooth road too. So any info about past experiences would help. thanks guys
post Dec 3, 2002 - 2:08 PM
Mizuryu
Joined Nov 8, '02
From Mongtomery Alabama
the only real thing i could tell ya is check your allignment... that's what was wrong with mine. I got mine fixed about a month ago and it's been fine ever since....does the wheel only shake like that when you're driving?
post Dec 3, 2002 - 4:46 PM
all4sho94st
Joined Aug 30, '02
From NoVa
i dunno but my steering wheel kinda shakes/vibrate when im like going 80 on the highway... i dunno why tho. Has this happen to anyone else.
post Dec 3, 2002 - 5:13 PM
jumpinccv
Joined Nov 11, '02
From Ohio
it typically does it worse when i drive faster, but not always the case in varies even in the same trip it can change vibration worseness, oh yeah, i had an alignment done too
post Dec 3, 2002 - 10:01 PM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
yeh I've got the shakes as well, had it for a while now. I know that my wheels arn't balanced. I also need a wheel alignment cuz the car pulls to the left. I've just been lazy as all hell to do it.
post Dec 4, 2002 - 1:09 AM
BigEdge169
Joined Nov 18, '02
From Texas
Do you have the stock wheels and tires on the car or do you have a plus size? With the bigger wheels and smaller sidewalls on your tires, you'll feel the road more pretty much no matter what you do compared to the stock feel. You might also want to check the air pressure in all your tires and make sure they're all about the same.
post Dec 4, 2002 - 2:36 AM
Benevolence
Joined Oct 9, '02
From San Diego, CA
Yeah my celi shakes at around 65 mph+, had my alignment done not too long ago so its not that.
post Dec 5, 2002 - 2:00 AM
Russkiy
Joined Nov 18, '02
I had the same problem about a month ago. Check your alignment, wheel balance and if it doesnt help then may be you should try to change your tires. That's what i did.
post Dec 5, 2002 - 4:22 PM
jumpinccv
Joined Nov 11, '02
From Ohio
they are stock tires and wheels, so that isnt it thanks for all the posts guys
post Dec 5, 2002 - 5:08 PM
Zoom
Joined Oct 15, '02
From Rochester, New York
Yea, I too shake at 65+. I figured it was either a stock problem or my alignment, or my wheels, but I imagine it's a combination of both your wheels and the stock settings not designed for high speeds on an ST ^^.
post Dec 5, 2002 - 5:42 PM
Mynzeyes
From Franklin/Nashville, TN
if the car stops shaking if you let off the gas, 9 outta 10 says it's an axle, my car has had this problem, and it's sittin up on jackstands waitin for a driver's axle. um...it shook in the 30-80mph range, and stopped when i let off the gas...check and see if any of your guys cars do that, then check the axle. wink.gif
-John-
AIM==Mynzeyes
post Dec 6, 2002 - 4:09 AM
Benevolence
Joined Oct 9, '02
From San Diego, CA
No, its not an axle, it still shakes if Im going 65+ and pop it into neutral.
post Dec 7, 2002 - 11:03 AM
CDNSLEEKA
Joined Sep 16, '02
From Yarmouth,N.S Canada
Well it looks like we have an epidemic on our hands, I must add my car to the numbers of this problem.I have all the same problems,and have done all the suggestions on cures for the problem.
IT has got to a point where this repair will be done before any further mods are done.Nothing more frustrating than jumping on the highway and reaching a good speed and having the car shake like s..t. This problem has become more evident after i spent 2500$ on rims&rubber not to mention eibach sportlines.
post Dec 17, 2002 - 11:03 PM
freestyler121
Joined Sep 28, '02
From Lancaster Ca
im not an expert here, but on my last car the sterrign wheel only shook when i put on the gas, in that case it was the axle and the half shafts going out, you should get it looked at as soon as possible. if it breaks when your driving your tire will lock up and you veer off the side fo the road, i did this going about 115 racing a camaro
post Dec 18, 2002 - 7:35 AM
CelicaLE
Joined Dec 2, '02
From North Carolina
I used to work in a service department at a car dealership...so I know a little bit bout this...lemme see if I can post my two cents worth! LOL
If the wheels shakes first thing I think I'd check would be the balance on all four tires. Only thing is, whoever you take it to...ask them to what speed they balance tires. at the dealership I worked at, the computerized balancing machine only balanced to about 72-73 MPH...so if you were over that speed you got the vibration.
Second I would check the alignment. if the alignment is off just a degree or so your car can ride horrible. Also, ask the shop you go to about possibility of checking the rear wheel alignment, to make sure everything is ok there. I know our cars are FWD, but it's a possibility something back there on the back end could be wrong and need to be checked.
Also, check your wheels. If you have curbed the car *hope not* but if you have, it is a great possibility the overall balance of the wheel is far enough off center, that you can't truly balance the tire. I've seen this happen many times where you can do a close job, but no matter what you do, you can never get the wheels in true balance.
Another thing I used to see is where the tires were wore wrong, like the alignment had been off, and the tire got bad wear in it, and it caused vibrations. I've seen that a lot too.
Those are probably the cheapest options to try to check. If that doesn't fix it, by all means take your car to someone who deals with suspension problems cuz it's in the suspension for sure.
Sorry this post is so long, and it may not be nothing new to you, but it's all I know from workin at the service dept! LOL
post Dec 23, 2002 - 7:35 PM
Blur
Joined Dec 9, '02
From Sacramento, CA
Damn seems like a lot of people are having this problem, i had this problem too awhile ago when i first got my car but it was only when i was braking hard. Had my brakes looked at and 700 dollars later no more shaking.
post Dec 23, 2002 - 10:23 PM
Guest_Jason_*
Yeaaa.. I had this problem. Once i'd hit about 80mph + my car would vibrate, the faster I went the harder it vibrated. Then I hit the curb in an icestorm and it sent me Car into the shop (where it still is now) so i'm hoping it'll comeback without vibration.
post Dec 23, 2002 - 11:11 PM
SiKBOY
Joined Nov 4, '02
I went for a wheel balance the other day and a wheel alignemt. My wheels are buckled so they said theres no point in balancing them cuz it won't make that much of a difference. Then came my alignment, they couldn't do it because my car was too low and it couldn't get on the hoist.
post Dec 26, 2002 - 8:22 PM
phat94celi
Joined Oct 9, '02
From Longmont, CO
Hey guys. I have the same problem. Check the tie rod ends(or have them checked), and also the ball joints. It could also be bad struts. I have semi new koni yellows and new tie rods that will hopefully help with the shaking, just havent had time to put them in.
post Dec 27, 2002 - 2:14 PM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
QUOTE (SiKBOY @ Dec 23 2002, 09:11 PM)
wtf kinda of place did u bring that too
bring it to another place dude
Lo-Fi Version Time is now: November 27th, 2024 - 4:02 PM
