> Problem need you help solving?
post Mar 7, 2005 - 2:52 PM
exxtractor
Joined Mar 31, '03
From BC
I jumped a car at the local costco for a couple who's battery was dead. Instead of listening to me the guy connected the negative on my car to his negative instead of the ground of his vehicle. Yesterday and today when I turn the key to start, I hear a clicking sound and nothing, do it twice and nothing, the third time it immediately starts without any trouble turning over. Never had this problem in the 5 years I've owned the car. Battery is about 3 years old from Toyota.
Any ideas? Alternator/battery/fuse?
post Mar 7, 2005 - 2:59 PM
Blakout16
Joined Jul 3, '04
From Yakima, WA
check your terminals for corrosion. im having the same problem right now... bought some terminal cleaners and a new negative connector.
bufferdan
Joined Nov 9, '03
From Dayton, OH
Whats the problem with connecting neg to neg?? Thats what i always do..its just the same as any other ground.
post Mar 7, 2005 - 7:13 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(bufferdan @ Mar 7, 2005 - 7:59 PM)
[right][snapback]254233[/snapback][/right]
I agree, its just an old myth. The negative line is connected to your chassis, so is there really a difference? no
post Mar 7, 2005 - 7:20 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
you prolly loosend the terminals tighten them up and you should be fine
haha I cant type today
DEF
This post has been edited by defgeph: Mar 7, 2005 - 7:21 PM
I will return one day.
post Mar 7, 2005 - 7:21 PM
nitemare
Joined Jan 12, '03
uhh.there is no problem at all.. u ARE suppose to connect negative to negative, positive to positive-as simple as that..
as far as your clicking sound, its your STARTER..its going...one of these days it will not start at all...
post Mar 7, 2005 - 11:47 PM
Rjb23
Joined Feb 8, '04
From KY
It could be your battery just coincedence that it happened now. 3 years old its time to get it checked out.
post Mar 8, 2005 - 11:22 AM
97GTinKC
From KC
The real reason you want to connect to a ground other than at the battery is to avoid any spark potentially causing the battery to explode, especially if the dead battery is half frozen. the acid fumes are highly flammable, not really too much of a worry now with the sealed batteries, but good to not take chances, battery acid can permanently blind you. (not to mention eating your car )
Lo-Fi Version Time is now: January 11th, 2025 - 7:52 AM
