> 7age with sliver top 20v, header
post Mar 7, 2005 - 3:58 PM
st_celica_killer
Joined Sep 23, '04
From fresno
hey..i think this question has been aske or not..but hey i'am gonna ask it anyways..... what kinda of header well be require or needed on a 7age??? with a 20
VALVE silver top head?????? or does it need to be custom mad for it to fit on the
7age??? and how much hp ? with the block completly stock and the
head stock ?? any tip would be nice??? thanks for the help pple... Going N/A
post Mar 7, 2005 - 4:07 PM
Are you seriously doing a 7A-GE? The fact that you have to ask which header to use doesn't exactly imply that you've got the knowledge/searching abilities to build a hybrid 7A-GE.
That said, the 20V stock header or a 16V 4A-GE header will work, the latter requiring modification. Two bolt holes on the outer flange of the header don't line up, so you have to weld on extra metal and drill new holes for the mounting bolts I believe. I've seen photos somewhere...if you search you'll find them eventually.
As far as horsepower numbers, I'm pretty sure that you don't use a stock block. I think pistons require changing, and the piston will affect compression, and therefore horsepower. You have a lot of research to do before you take on a project like this.
post Mar 7, 2005 - 4:42 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Tis why I avoid answering such questions in detail. The tech guys can tell when a person is capable of doing such a conversion... and will give answers accordingly. It's not that we're holding back... but if you can't figure out such simple things... you're never gonna understand what it takes to tackle such a project. I personally considered doing this set-up to my AE86, but after long thinking and consideration, I decided against it. There is a weakspot in the 7A that can hurt performance...
post Mar 7, 2005 - 5:38 PM
st_celica_killer
Joined Sep 23, '04
From fresno
well thanks for the help you guys.....?? all i just wanted was to get some idea from you guys first?? but it doesnt hurt to give it a shot ....by the way i'll see if i can get some header from japan..since this one guy...owns a shop say he can..? so i guess well just have to see happen..thanks for the help
post Mar 7, 2005 - 11:09 PM
st_celica_killer
Joined Sep 23, '04
From fresno
hey coomer since you have done a 4age 20v inside yours??? did you hook up the vvti??whatever its calll.and does it makes any diffence at high end......also how far is your redline???
post Mar 8, 2005 - 12:20 AM
QUOTE(st_celica_killer @ Mar 7, 2005 - 8:09 PM)
[right][snapback]254419[/snapback][/right]
No 4A-GE engines have VVT-i. I have VVT hooked up though. It does make a difference throughout the entire RPM range, and I redline at 7800. Anything else you need to know can be found through searching.
Lo-Fi Version Time is now: January 11th, 2025 - 7:50 AM
