> Full interior removal, Options and warnings
post Mar 7, 2005 - 11:20 PM
spunky393
Joined Apr 22, '04
From illinois
One of these weekends (if it's warm this weekend), i'm going to wake up and start on my car right away. I want to remove all of the panels, doors - back, and foam strip wrattles, correct wire connections, etc. (what i mean by wire connections, is when i spliced into my rear speakers for the amp (i have a stock reciever), i was workign blindly, i did a good job, just want to make it better. So, i guess i just want opinions and warnings
post Mar 7, 2005 - 11:30 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
make sure all the screwes are out of a peace befpore pulling out. and put all screwes in lil baggies. I have to many missing screwes in my car rolleyes.gif .. lol.. Also have a few broken plastic peaces too.. but it was like that when i bought it.
post Mar 8, 2005 - 1:28 PM
spunky393
Joined Apr 22, '04
From illinois
thanks, Dingndoug, any other info is appreciated
post Mar 8, 2005 - 3:38 PM
If you're removing the dash, pull your steering wheel. It'll make it a lot easier. Aren't you just pulling the rear seats and side panels though?
post Mar 8, 2005 - 6:05 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
of course when doing steering wheel disconnect battery for several minutes before working on it, and make sure key is in "lock" position.
post Mar 9, 2005 - 6:36 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
It would also be a good time to inventory what you need and what needs to be replaced. You might need a screw here and there.
Lo-Fi Version Time is now: February 17th, 2025 - 7:35 PM
