fuel pump going out? |
Mar 8, 2005 - 12:13 AM |
Enthusiast Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
ok first i had 150miles per tanks...added fuel injector cleaner and for some odd reason got like 300...car drives fine all the time until yesterday when i turn it on...when in neutral the rpms go from 500-1500 and move around in between like crazy...when revving the engine, throttle is very very sluggish and it feels like im being kicked cuz the engine jolts and sputters...car runs fine in upper rmps but on lower rpms it is very very jolty as if there is not enough fuel flow to the engine, when driving the car seems to drive like it has a flat as if its gripping the road like crazy and doesnt want to coast at all....the tranny seems fine and there no knocking or anything in the block, temps r fine, air intake fine, no water in the engine i dont know whats up any ideas??
Mar 8, 2005 - 4:26 AM |
Enthusiast Joined Jan 23, '05 From Avondale, AZ Currently Offline Reputation: 0 (0%) |
I had a similar problem in my 4Runner a few months ago, and what had happened was a spark plug wire had come loose. Maybe that might be something to check, or maybe you have a bad plug. Also, when you put the fuel injector cleaner in, maybe you had a dirt claude or something that was dislogged and now found it's way into the injectors. Just a thought, but I'm probably wrong.
Mar 8, 2005 - 1:15 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Had the exact same problem a month ago. Change your fuel filter, its probably clogged.
My car ran fine at about 3k rpms or higher but when below that it jerk and sputter and sometimes take off like it had a mini turbo. Then when idling it would drop way low then jump high. Basically it acted like it was running on 3 cylinders. It had no acceleration at all and when taking off it acted like I was dumping the clutch and it wanted to stall out. This post has been edited by Rjb23: Mar 8, 2005 - 1:18 PM |
Mar 8, 2005 - 5:55 PM |
QUOTE(Rjb23 @ Mar 8, 2005 - 1:15 PM) Had the exact same problem a month ago. Change your fuel filter, its probably clogged. My car ran fine at about 3k rpms or higher but when below that it jerk and sputter and sometimes take off like it had a mini turbo. Then when idling it would drop way low then jump high. Basically it acted like it was running on 3 cylinders. It had no acceleration at all and when taking off it acted like I was dumping the clutch and it wanted to stall out. [right][snapback]254642[/snapback][/right] well didnt have time to look at it needed it for work took it to shop they say fuel filter fine...spark plugs bad...but then drove it home and am gonna order new wires and plugs but car ran perfect home like new no engine light???? makes no sense |
Mar 9, 2005 - 1:32 AM |
When you took it to the shop, maybe they pulled the spark plug out and that's all it was, maybe the spark plug had just come loose, or maybe the wire had and when they hooked it all up again, they tightened it up or something, but at least it's running good again.
Lo-Fi Version | Time is now: January 11th, 2025 - 9:54 PM |
