Bump bump ::silence:: bump bump |
Mar 8, 2005 - 3:50 PM |
Enthusiast Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) |
Ok so here's my problem: I just upgraded my system (1 10" alpine r in a large sealed enclosure... I'll get pics..) and sometimes my system just stops bumping intermittently.. Amps not runnin hot, voltage is constant, ground and power wires are all properly ran and connected/grounded.. Any ideas? Anyone?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." |
Mar 8, 2005 - 3:54 PM |
Enthusiast Joined Nov 8, '04 From Carmi, Illinois Currently Offline Reputation: 0 (0%) |
well go over all of your wireing.... check your RCA's, also sometimes the screws to clamp down the speaker wire and ground, bat, and rem. wire can come lose... also check the wiring on the sub...
This post has been edited by Scarrell: Mar 8, 2005 - 3:54 PM -------------------- i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U. TrickedOutS2000: it was a vibrator my dad bought scarr3ll: WHAT THE ****?!?11 TrickedOutS2000: yeh TrickedOutS2000: for my mom im guessing TrickedOutS2000: but yeah TrickedOutS2000: eww TrickedOutS2000: so TrickedOutS2000: ****ing TrickedOutS2000: wrong My Cardomain Page. Car Audio Central msn: jared_s_c@hotmail.com aim: Scarr3ll |
Mar 8, 2005 - 4:03 PM |
Enthusiast Joined May 6, '04 From antioch CA Currently Offline Reputation: 0 (0%) |
What type of amp are you running?
Mar 9, 2005 - 10:46 PM |
All wiring is secure (RCA's, Power, Ground, Remote turn on etc etc)...
I'm running a 600 watt rockford amp (Prolly more like 300 watts) -------------------- Fred
Mar 9, 2005 - 10:51 PM |
Enthusiast Joined Nov 30, '04 From Atlantic City Currently Offline Reputation: 21 (100%) |
i remember when that happened with my cousins' system (2 10inch Rockfords) it was because his ground wire was loose. not sure what it is in your case and i know you checked your wires, but it's worth another shot.
Mar 9, 2005 - 11:13 PM |
Im thinking maybe I should upgrade the power and ground wires maybe.. it could just be too much of a restriction for the power needs of the actual subwoofer its self.. I tried adjusting the gains and levels to see if that would stop it but only if the settings were barely pushing the sub at all..
Mar 10, 2005 - 4:27 AM |
upgrade? why? upgrading wont do much except help current... check your grounds man.. switch power wires, switch remote wires and ground wires.. you might think it is ok but it might now be.. make sure the ground is on BARE METAL.. check ALLLLL connections..
Mar 16, 2005 - 4:43 PM |
Enthusiast Joined Dec 2, '04 From Surrey, England Currently Offline Reputation: 0 (0%) |
I also had this problem repeatedly until lately. Sometimes the sub would work fine, other times (usually for the first ten minutes of driving) the amp would switch on and off every few seconds, real irritating! I ran the remote and RCA leads down through the centre of the car via the console and uner the carpet, whereas previously it ran side by side with the power cables in the duct under the door sill. Now it works fine and I can only put it down to the power cable inducing a false current in the remote cable, my cd changer also sounds slightly better now too. I'm guessing you too are running all your cables together so I would suggest seperating them out as I did.
Hope this works for you. Dan T |
Mar 16, 2005 - 4:54 PM |
Enthusiast Joined Apr 22, '04 From Rhode Island Currently Offline Reputation: 3 (100%) |
running cables together = very baddddd.... i ran my rca and remote on one side through the door jams, and power on the other side thro door jam... best way to do it
Mar 16, 2005 - 5:00 PM |
QUOTE(DamDirtyApes @ Mar 16, 2005 - 1:54 PM) running cables together = very baddddd.... i ran my rca and remote on one side through the door jams, and power on the other side thro door jam... best way to do it [right][snapback]258080[/snapback][/right] If the RCA cables are only going to an amp to power a sub, I guarantee that you won't hear a difference if you seperate the cables, provided that your cables are all intact and in good condition and not shorting out or whatever. The little bit of interference that can be caused by running RCAs side-by-side with power wires is inaudible by the ear on a subwoofer. Yeah, it's better to run the wires seperately, but it's not going to make a difference if the wires are only going to a sub amp. -------------------- New Toyota project coming soon...
Mar 17, 2005 - 2:27 AM |
I don't think this was a problem with the sound quality, just that the amp is literally not working properly. I agree though that there would be no effect on the RCA's for the sub drivin' amp, the cd changer however now has a lot less background hiss and the sounds slightly sharper at high volume than it did before.
I think we can agree though that running the remote lead away from the power is a good idea. Dan T |
Mar 19, 2005 - 12:21 AM |
check the fuse.
Mar 20, 2005 - 5:04 PM |
Enthusiast Joined Oct 7, '04 From Illinois Currently Offline Reputation: 0 (0%) |
I'm just gonna be blunt about this. Get a new amp and have a professional install it!
Lo-Fi Version | Time is now: November 30th, 2024 - 9:57 PM |
