transmisson fluid, need help |
Mar 9, 2005 - 4:08 AM |
Enthusiast Joined Apr 29, '03 From socal Currently Offline Reputation: 0 (0%) |
my transmission fluid is bad like black color some ppl tell me to change the fluid some say dont an leave it...im not sure wat to do i have a 94 celica gt...thank you
Mar 9, 2005 - 6:40 AM |
Enthusiast Joined Apr 19, '03 From Washington Currently Offline Reputation: 0 (0%) |
well, its easy to change transmission fluid on a manual...its just taking out a screw to drain and taking out another to fill..its just getting the fluid inside which is the tricky part... when i replaced my halfshafts i had to drain my transmission...and i just put a hose in there with a funnel on the end to get about 2.5 quarts of Full Syn Gear Oil.... but if its black i would replace....however the only way you would know is if you pulled it plug and let it drain....
Mar 9, 2005 - 11:59 AM |
I'd replace it if it's black for sure. It's not hard at all...I've posted detailed instructions on doing it in the past if you want them.
Lo-Fi Version | Time is now: January 12th, 2025 - 4:23 AM |
