> Wheel stud replacement, question
post Mar 10, 2005 - 2:11 AM
jgreening
Joined Jan 17, '04
From Illinois
Simple question. When replacing the wheel studs, do you need to take off the hub?
post Mar 10, 2005 - 2:23 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
yea i need this too, last person who touched my old wheels forced one of my lugs on with air tools and when i took it off it stripped then snapped off.
thanx.
Team 6gc 2005
post Mar 10, 2005 - 5:28 AM
Hanyo
Joined Aug 16, '03
From Bay area
from my experience..
yes you need to remove the hub. or there will be no room for you to put the new stud in..
post Mar 10, 2005 - 12:29 PM
97GTinKC
From KC
The shop manual says you can do it without removing the hub by using a nut and washer to pull it thru, just keep tightening the nut til the stud is seated, use a pry bar to keep the hub from turning, and make sure the new stud is started in the hole straight and dont let the stud turn.
post Mar 10, 2005 - 12:45 PM
prpnum1
Joined Aug 7, '04
From US
you dont need to remove the hub. i just did this recently. just tighten the studs by hand as much as possible and then when you put the wheels on and tighten those it will pull the stud in the rest of the way.
post Mar 10, 2005 - 12:51 PM
jgreening
Joined Jan 17, '04
From Illinois
How do the old ones come out?
post Mar 10, 2005 - 9:51 PM
jgreening
Joined Jan 17, '04
From Illinois
Anyone?
post Mar 10, 2005 - 10:00 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Tap it out. You'll need to remove the caliper and turn the hub till the stud you want to remove is on the caliper side. It's different for every car, but I believe there is enough space to tap out the stud once the caliper is removed. Usually Toyota is good about drilling out a spot or leaving space for stud removal.
post Mar 10, 2005 - 10:25 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(Kwanza26 @ Mar 10, 2005 - 10:00 PM)
[right][snapback]255869[/snapback][/right]
Thank you.
post Mar 12, 2005 - 5:24 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
Kwanza26 is correct as usual. You can hammer the old studs out and install new ones on the car. I did waht prpnum1 suggested, but I tightened each stud using a couple nuts to ensure that the studs were seated before mounting the wheels.
post Mar 12, 2005 - 6:09 PM
prpnum1
Joined Aug 7, '04
From US
yup that is it you can use the lug nuts to tighten as much as possible first before the wheel finishes it off
post Mar 15, 2005 - 1:19 PM
97GTinKC
From KC
tapping out is ok, dont get carried away, could damage bearings, best to brace the hub with something and pound against that, shop manual shows a c-clamp type tool that you hook around the hub and tighten against the old stud. just a c-clamp with a u-shaped notch cut out to clear the back of the stud
Lo-Fi Version Time is now: November 30th, 2024 - 10:52 PM
