> Camshafts, where???
post Apr 4, 2003 - 1:22 PM
edo17982
Joined Dec 21, '02
From Italy
Hi guys!
Do you know if there is someone who produce more performant cams for 7AFE engine?
the only site I found with aftermarket cams is Import performance
which sells TopLine cams. Who know about this manufacter?is it good?
Also, does anyone know how to get regrinds, valves and springs for better performance and which are stronger than stock?
post Apr 23, 2003 - 6:13 AM
edo17982
Joined Dec 21, '02
From Italy
None?
post Apr 23, 2003 - 2:52 PM
Charlie97L
From North Bethesda, MD
you'll have to get them custom re-ground, or just custom, period. no one makes performance camshafts for the 7afe. why would they? it's an economy engine. and besides, to get decent power, you'd have to go with such a high lift that your idle would be terrible, not pleasant to drive on the street. i'd expect about a 10 HP gain from getting your camshafts reground.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Apr 23, 2003 - 3:00 PM
west_minist
Joined Oct 27, '02
From Barbados
My advice to you is to swap with the 4AGE 16v/20v
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Apr 23, 2003 - 8:19 PM
edo17982
Joined Dec 21, '02
From Italy
I know West, but in Italy I'm going directly to jail if I do a swap and I also loose the insurance coverage in case of accident.....that's the way I don't do it. frown.gif
Check in my profile my performance mods. If I'm going for a reground, which duration values should I use? confused.gif
post Apr 23, 2003 - 10:08 PM
west_minist
Joined Oct 27, '02
From Barbados
Ok. understandable.
But if you modify, and you get in an accident, what?
post Apr 23, 2003 - 10:38 PM
FallenHero
Joined Dec 26, '02
From Alabama
I'm surprised. I though america was the only place with the crap 7a in a celica.
post Apr 24, 2003 - 12:21 AM
zigy
Joined Nov 6, '02
From Chicago, IL
hey west_minst .... how about going with 4AGE automatic ..... possible??????
post Apr 24, 2003 - 5:33 AM
west_minist
Joined Oct 27, '02
From Barbados
yep, that can also work.
I think the automatics have a slightly bigger cam than the manual.
Either way, if you are going to use a manual later, it is wise to get a manual ecu or an aftermarket computer since the maps will be set up differently.
West_Minist
http://www.socob.bb
post Apr 24, 2003 - 6:19 AM
edo17982
Joined Dec 21, '02
From Italy
QUOTE (west_minist @ Apr 23, 2003 - 7:22 PM)
Ok. understandable.
it depends by the type of accident.....maybe if it's cause u're going too fast (and in Italy we ALWAYS go over the limit.... rolleyes.gif ) there are some complications......anyway....do you know which durations may I use for cams? wink.gif
post Apr 24, 2003 - 6:20 AM
edo17982
Joined Dec 21, '02
From Italy
QUOTE (FallenHero @ Apr 23, 2003 - 7:52 PM)
oh no.....in europe we've the ST with 7AFE but with rear discs wink.gif and the GT with 3SGE, and naturally the GT4 biggrin.gif biggrin.gif biggrin.gif
post Apr 24, 2003 - 7:35 AM
west_minist
Joined Oct 27, '02
From Barbados
Ok.
I believe that you duration right now maybe 228 -234.
If so, 254 - 262 maybe go.
Cranecams or MSD will help you out here.
You need to get a cam to operate in the engine sweet spot..
If you are going cams, get a customer header build bu pitshop or some other muffler dealer..
with new cams, look to increase air flow filter , 2.2 -2.5" exhaust with high flow muffler with increase of fuel for more HP & Torque
post Apr 24, 2003 - 8:09 AM
edo17982
Joined Dec 21, '02
From Italy
you mean 254 for intake and 262 for exhaust or 254 - 262 for both?
post Apr 24, 2003 - 8:34 AM
west_minist
Joined Oct 27, '02
From Barbados
MSD or cranecams will help you on this.
I all 256 or all 262.
It maybe better to go with 256 since your engine might now be able to rev to 8000rpm.
post Apr 24, 2003 - 8:37 AM
edo17982
Joined Dec 21, '02
From Italy
so 256....ok
If I regrind I cannot change the lift....what about the (I don't know to say in english) cross values?
post Apr 24, 2003 - 6:45 PM
Charlie97L
QUOTE (west_minist @ Apr 24, 2003 - 5:48 AM)
no, cams don't allow you to rev higher, valve springs do.
there are NO cams for the 7afe, i don't know why you people are all talking about like 256 and 264 for.
there's basically only 1 way to regrind your cams. webgrind or weber cams or something like that, reground some guy's 5sfe cams. it was like 600 bucks i think. but if you're in europe, i have NO idea.
1994 Lexus ES300
1989 Supra Turbo
post Apr 24, 2003 - 10:30 PM
edo17982
Joined Dec 21, '02
From Italy
QUOTE (Charlie97L @ Apr 24, 2003 - 3:59 PM)
I think you're not right charlie....the cams let you get higher RPM band....Of sure if u're going to get more RPMs you need better valve's springs to avoid the risk of a crap wink.gif ....also better retainers are suggested for high RPMs, but as I know are the cams that let you reach an higher RPM band....
This post has been edited by edo17982: Apr 24, 2003 - 10:32 PM
post Apr 25, 2003 - 6:16 PM
west_minist
Joined Oct 27, '02
From Barbados
QUOTE (Charlie97L @ Apr 24, 2003 - 5:59 PM)
Hi guys, please read carefully.
I stated that he should get cams in the engine sweet spot.
If you get big cam, over 262, you will have to rev a little more for more power.
These is also the problem that the engine will not be able to use the big cams due to small ports and vavle size and other small factors.
Is that clear enough?
West_Minist
http://www.socob.bb
post Apr 25, 2003 - 6:18 PM
west_minist
Joined Oct 27, '02
From Barbados
so charlie, you are saying that cranecams or msd cannot produce cams for you?
post Apr 26, 2003 - 2:13 AM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (west_minist @ Apr 25, 2003 - 3:32 PM)
I believe they regrind your stock cams...
Anyways, there's no real point in going with performance cams unless you're gonna build an all-motor track engine. I mean, re-ground cams idle like crap, typically shift the powerband into the high rpms, and make a daily driver drive like crap, especially since the 7A is already a fairly weak low-end motor.
And... why do you keep telling people to get 2.5" catbacks? That's too huge for 4 cylinder cars, even 6 cylinders. You'll lose more than you gain.
And about revving... your stock cams can rev beyond redline... it's the ECU that automactically cuts fuel... The revving isn't limited by the cams, it's the electronics.
Lo-Fi Version Time is now: November 30th, 2024 - 10:56 PM
