> Making My Own High Pressure Hoses/Lines, Can it be done?
post Mar 11, 2005 - 11:50 PM
I've got a problem. My stock A/C lines(metal to rubber to metal) need to be mated to the metal ends of my AE101 A/C lines.
Does anyone know of a way to make a high pressure line that would work for this?
I thought about finding some really thick rubber hose and then using several very tight clamps on the end of the hose where it goes over the metal parts. Does anyone know if this would work?
Also, doesn't the A/C system only push about 40 PSI max through the lines?
post Mar 12, 2005 - 12:06 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
im using that for my oil lines for the turbo and thats 50psi u should be fine. buy cloth re-enfored rubber tubing.
post Mar 12, 2005 - 12:09 AM
Where do you buy that kind of tubing?
Also, I just found out that the high-pressure hose is subject to pressures ranging from 150-285 PSI.
post Mar 12, 2005 - 5:25 PM
mark_426
Joined Jan 30, '05
From Greencastle, PA
What size is the hose/are the fittings (sorry for my ignorance to that).. also, how long do they need to be?
Theres a few things I've got in mind, but don't know enough to know whether or not they'd work for size..
post Mar 12, 2005 - 9:25 PM
Hanyo
Joined Aug 16, '03
From Bay area
i would think the rubber hi pressure hose cant handle how cold the freon gets. I would becarefull attempting to make your own.
post Mar 12, 2005 - 9:37 PM
orvillescelica
try http://www.mcmaster.com/ they have everything and everything you could ever need and in almost every size.
look at their rubber tubing, they give you its temp range and pressure rating for their different kinds.
post Mar 12, 2005 - 11:59 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
Earls Hoses are good.
post Mar 13, 2005 - 1:08 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
carquest makes custom high pressure hoses.
sliding on the rubber and clamping it will not work.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
Lo-Fi Version Time is now: February 19th, 2025 - 7:24 PM
