> Audio causing outside to rattle, I've pin-pointed
post Mar 13, 2005 - 1:09 PM
spunky393
Joined Apr 22, '04
From illinois
The ONLY rattle coming from my car is outside, and outside, i found that in the back tail gate (hatchback), that part where the licence plate is, is the rattle. Now, it's not exactly that plastic peace, it's the FREAKING LICENCE PLATE LIGHTS. I just barely put any pressure on the light fixture (above licence plate) and all the rattling stops. HOW IN THE WORLD DO I GET IN THERE?????????
post Mar 13, 2005 - 1:20 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
wow, thank you. ive had that rattle pissing me off for a while and couldnt find it. when i get some spare time ill look into it and let you know what i did and if what i did helps.
post Mar 13, 2005 - 2:15 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
To get the rear panle off, first you need to get into your hatch. Then take off the inside rear panle with the few screwes holding it in. Then take off the three nuts holding each of the tail lights on. Then there should be three screwes or pops, that will come out very easy. Then the panle comes out and put some dynomat over or unsder what ever is making noise and rattleing.
post Mar 14, 2005 - 1:10 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
If your not rattling, your stereo's not loud enough. my whole car rattles!
post Mar 14, 2005 - 1:33 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
lol tru that... if ur air intake is rattling when ur car is off from the bass.... thennn its loud enough. tongue.gif
post Mar 14, 2005 - 8:42 AM
nightrider
Joined Apr 26, '04
From London
Tune your bass box to sub base waves, sounds clear and very punchy!!
More Power to your BOOM BASS
post Mar 14, 2005 - 10:50 AM
darksecret
Joined Mar 9, '05
From Charlotte
check your door handles and wing also mine rattle some but its enough to get annoying
post Mar 20, 2005 - 8:36 PM
Celica_Kid95st
Joined Feb 24, '05
From Pittsburgh, PA
QUOTE(nightrider @ Mar 14, 2005 - 8:42 AM)
[right][snapback]257085[/snapback][/right]
how do u do that? whats the button that u turn called?
post Mar 20, 2005 - 9:42 PM
^^ that won't stop rattle
but its gain and lpf/hpf ect...
air intake rattle when the car is off HA thats not even loud
when your thumping it and your neighbor 6 houses down comes out cause her china fell off the shelf now THAT is loud enough
post Mar 21, 2005 - 3:14 AM
Scarrell
Joined Nov 8, '04
From Carmi, Illinois
messing with the gains isnt a good idea unless you know what to set it too.... if you have your gains all the way up then you arent very smart... the gains are not for bass...... it isnt a volume knob..... remember.... distortion blows speakers/subs..... anyway..... my whole car rattles... and the F#cking wing rattles like no other... i have loosened the screws but the wing still wont come off.. any ideas? also i want to re-glue it.. any suggestions on that?
i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U.
TrickedOutS2000: it was a vibrator my dad bought
scarr3ll: WHAT THE ****?!?11
TrickedOutS2000: yeh
TrickedOutS2000: for my mom im guessing
TrickedOutS2000: but yeah
TrickedOutS2000: eww
TrickedOutS2000: so
TrickedOutS2000: ****ing
TrickedOutS2000: wrong
My Cardomain Page.
Car Audio Central
msn: jared_s_c@hotmail.com
aim: Scarr3ll
post Mar 26, 2005 - 8:03 AM
CelicaRacer97
Joined Nov 29, '02
From Menifee CA
on my celi its the taillights that rattled....i stuffed some newspaper to keep it from rattling lol...ill stuff something better when i get a chance...but it doesnt rattle anymore
post Mar 26, 2005 - 12:35 PM
TRD6GC
Joined Nov 17, '03
Yea my whole trunk, trunk lid, and under my back seats is dynamated.....still rattles. Rattling isn't a bad thing!!!! My licences plate lights rattle too, there each held on by two screws, take them out and mess with them to sit in tight with dynamat or something, you shouldn'd need to take that whole lic plate holder piece off. And you def know when your *hits loud when your rear seal in your hatch breaks.......As for the wing, you gotta take all the screws out and it should come right off. Some of them may be blocked by rubber pieces, just take them out. Some times the actual inside of a wing rattles, pending on how its made, my friend had that problem and couldn't fix it.
post Mar 26, 2005 - 12:49 PM
rocky2006
Joined Aug 18, '04
i have rattles, bangs, and whistles (exaggeration) coming from all around my trunk. i dont even know where to begin. my taillights are fine and my license plate lights are fine. my entire trunk panel moves up and down when the bass hits. i think the hatch panel rattles on mine, but that is only 1 out of many. if you guys find anything else that rattles, post it.
post Mar 26, 2005 - 1:27 PM
TRD6GC
Joined Nov 17, '03
MY WAY OF FIXING SOME ANNOYING RATTLES:
Ok first you need to go to home depot or somewhere and get door foam insulation. It basically a long strip of foam with a sticky side. To do it right take out ALL or most of your interior plastic pieces. Now when you put them back in put a piece of the foam whereever they touch or clip together. You can also put the foam where it touches the car as well (i.e.: the big plastic piece that clips to the hatch sometimes vibrates against the hatch so you could put foam under that). You can also put the foam on the back of you lic plate around the edge and in the center a little. And bend or arch your lic plate when you put it back on, this puts pressure against the foam and stops the rattling. This won't fix everything but its a quick fix for MOST of the rattling we have. Just a little info that helped me so i figured i'd share.
post Mar 26, 2005 - 2:24 PM
Scarrell
Joined Nov 8, '04
my back hatch whistles... the damn bumper makes a whistle noise...among the other rattles....if you want some good sound deadener... look at Brown Bread... you can get a 100sq ft of it for $100... which is a super good deal.
TrickedOutS2000: so
My Cardomain Page.
Car Audio Central
aim: Scarr3ll
Lo-Fi Version Time is now: November 24th, 2024 - 4:32 PM
