> gas pedal problem?
post Mar 14, 2005 - 1:21 PM
celicaboston1983
Joined Mar 20, '04
Hey does any one else has this problem, when its kinda cold out maybe low teens to low 20 does any of your gas pedals gets kind of stuck/hard? I was driving the other day stopped at the lights turns green i step on it and it feels like stuck and i had to stomp on it to free it. Is this normal?
post Mar 15, 2005 - 4:25 AM
popstar
Joined Nov 24, '04
From Moscow, russia
NO !!!!
this is not normal !
check for any dirt or kinks in the cables, then gets some oil out !
Life is for living, and you don't get a second chance
Take care now !!
post Mar 15, 2005 - 6:54 AM
slipgun
Joined Jun 2, '03
From Annandale VA
post Mar 15, 2005 - 9:34 AM
1bwilson
Joined Aug 30, '02
From Maryland
Mine does it too. Ive had it adjusted but still happns. Cant figure out why. I just tap the gas to feel for play before startup.
Member of Team 5sfTe
post Mar 15, 2005 - 10:24 AM
lil_lissa
Joined Feb 8, '05
From Cambridge, ON, Canada
i get this all the time too! well before the car is warmed up anyways
its not like the gas won't go and i have to pound it or anything, its jsut i like things smooth.. so when im just lightly touching it to start going.. it needs some help.. smile.gif
lissa | 1997 Celica Convertible
*My other ride is your boyfriend* ;)
post Mar 15, 2005 - 11:06 AM
My '95 Celi had the same problem when it was drivable, except it did it all the time. I never bothered to check out what was causing it though.
post Mar 15, 2005 - 11:49 AM
lube up all the moving parts from the gas pedal to where the cable connects to on the motor
post Mar 15, 2005 - 1:11 PM
97GTinKC
From KC
cable may be getting frayed inside and getting ready to break, classic symptoms,,,unhook it from the pedal and throttle body and verify its smooth thru the full travel. the individual strands start breaking and catching inside the housing, eventually it could stick in about any position. lube it if its smooth and free and put it back, otherwise replace it.
post Mar 16, 2005 - 1:18 PM
celicaboston1983
Joined Mar 20, '04
I dunno its been ok lately i guess its the weather. But still gonna go to the shop and check it out. Is it a common thing for celicas cause my bro and my cousin always complaing about their pedals being hard both 5th gens gts
post Mar 16, 2005 - 6:53 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE(slipgun @ Mar 15, 2005 - 6:54 AM)
[right][snapback]257501[/snapback][/right]
you know that is a common thing
post Mar 16, 2005 - 11:19 PM
Rjb23
Joined Feb 8, '04
From KY
I have the same problem. I dont think its the cable itself I think its the throttle at the throttle body. Because I can get out and just manually give it gas and it gets stuck at the TB if that makes sense.
post Mar 17, 2005 - 1:16 AM
UTSlickVic
Joined Mar 6, '05
From Fort Worth, TX
I have the same prob, except its all the time. I am very intrigued that many people have this prob. I tried lubbing up the hinge/coil-spring points behind the pedal. It stop for a week or two but it gradually started up again. I used WD-40, I really should have used some real grease. I think I'll try some things out this weekend. I'll keep yall posted.
Lo-Fi Version Time is now: December 4th, 2024 - 4:39 AM
