Installing my Premier 770, How do I? |
Feb 3, 2011 - 11:12 PM |
Enthusiast Joined Jun 29, '03 From 캘리포니아 Currently Offline Reputation: 23 (100%) |
Hey speaking of the 6 speaker system, do you guys know how the factory tweeters are wired in? do they run in parallel with the door speakers or is there a hidden crossover? They are wired in parallel with the door speakers with no crossovers. -------------------- |
Feb 4, 2011 - 2:37 PM |
where do the wires join? behind the headunit or somewhere half way thru the kick panel
-------------------- Mike W
Feb 4, 2011 - 7:36 PM |
where do the wires join? behind the headunit or somewhere half way thru the kick panel The wires join from inside the door panel. You'll have one 2 wire harness coming from your tweeter, and another 2 wire harness coming from your speaker. They both meet about 8" in from the connectors. -------------------- |
May 12, 2011 - 1:51 PM |
Enthusiast Joined May 3, '11 From Ohio Currently Offline Reputation: 8 (100%) |
I have the 8 speaker system in my car. A previous owner had Circuit City put in the stereo and they spliced EVERYTHING into the wiring harness. my large door speakers don't work, but the rears, the tweeters and the 4" speakers work. I would like to get the front door speakers working and am looking at putting the wiring harness back together and using a PROPER adapter plug. I don't know which model adapter to get however. I'm looking at this page
http://www.bestbuy.com/site/olspage.jsp?_d...ries&ks=960 and there are several different model adapters, but noone has said thus far which ones work and which ones don't. Any advice would be greatly appreciated Thanks Trace -------------------- |
Jul 13, 2011 - 7:17 PM |
UPDATE:
Circuit city thought it was a good idea to get rid of the black part of the harness that goes from the stock OEM amp to the stereo and pull out the wide plug out of the amp.... then take that plug, clip half the wires, and splice the stereo in. I only found this out after talking EXTENSIVELY to the guy in the best buy car audio dept. SO, i'm missing part of the harness and I'm still not sure if I got the right harness because he had two harnesses. One of the harnesses is for a stock system, and one for a JBL system. I have three plugs in the amp and am still not sure which one I have. Any ideas or extra commentary would be appreciated. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:13 AM |
