![]() Enthusiast ![]() ![]() Joined Jul 21, '04 From Fresno, CA Currently Offline Reputation: 1 (100%) ![]() |
i think i seen a post like this before but yeah... what offset will fit our cars and will not fit our cars??..thanx..also does anyone know the offset of the stock alloy??..
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(blackbullet @ Mar 17, 2005 - 12:21 AM) i think i seen a post like this before but yeah... what offset will fit our cars and will not fit our cars??..thanx..also does anyone know the offset of the stock alloy??.. [right][snapback]258271[/snapback][/right] stock is +38 you should be ok with 5 mm in either direction |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(gh0st_d0g @ Mar 16, 2005 - 11:36 PM) QUOTE(blackbullet @ Mar 17, 2005 - 12:21 AM) i think i seen a post like this before but yeah... what offset will fit our cars and will not fit our cars??..thanx..also does anyone know the offset of the stock alloy??.. [right][snapback]258271[/snapback][/right] stock is +38 you should be ok with 5 mm in either direction [right][snapback]258282[/snapback][/right] As long as you stay with 7.5" wide wheels or under. Anything bigger and you will need to watch the clearance on the inside of the wheel. Coomer has posted a picture of a white car with 8" rims and a 35 offset and I would bet that thing barely clears. This post has been edited by jgreening: Mar 16, 2005 - 11:56 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) ![]() |
also i would recommend 225 or less tires, i got 235/45/17's and it barely clears and the way it is now i can't even drop my car at least until i change tires.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
actually stock offset is +40, its stamped right on the back of the gt's rims
![]() -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) ![]() |
I have +45 on my car and they look great.
i have some rims offset of 42 and they don't fit.. the lug nuts barely go in a little only..they are 17x7...i was thinking of drilling them so the lug nut can go in deeper so the offset would be smaller...is that a good idea??..
my rims are +42 and they fit fine. maybe the lugnuts just aren't fitting in the sockets properly? I couldn't use the stock nuts on mine so I bought some generic 'tuner' style ones
QUOTE(blackbullet @ Mar 17, 2005 - 10:44 PM) i have some rims offset of 42 and they don't fit.. the lug nuts barely go in a little only..they are 17x7...i was thinking of drilling them so the lug nut can go in deeper so the offset would be smaller...is that a good idea??..
[right][snapback]258807[/snapback][/right] |
actually my bad..i double checked again and the offset was +45...so i guess i would have to drill it..how much do you guys think it will cost me?....
QUOTE(blackbullet @ Mar 19, 2005 - 3:36 AM) actually my bad..i double checked again and the offset was +45...so i guess i would have to drill it..how much do you guys think it will cost me?.... [right][snapback]259385[/snapback][/right] Drill it? I would buy some tuner lug nuts like Ghost Dog mentioned. If you do not have enough of the lug showing after you put your wheel on, you need one of two things to make the wheels work: (1) new nuts; or (2) new lugs. As for the 45 offset, it will either interfere with the strut housing or it wont. I don't know about 45. If it does, then you have to buy yourself some wheel spacers. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Lo-Fi Version | Time is now: February 24th, 2025 - 12:26 PM |
