SEAFOAM, wow this stuff works! |
May 10, 2005 - 7:36 PM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
Pray?
Seriously tho, you should get it checked out, my celica used to do that and I was told by a close friends (who's a mechanic) that when he listened to it w/ a stethoscope or w/e thats what he thought it sounded like. Thats why I'm swapping. IF it is a rod, then your best bet is a rebuild or a new motor. -Ryan -------------------- AIM : FAQdaWorld
May 10, 2005 - 7:40 PM |
Enthusiast Joined Apr 25, '05 From Canada Currently Offline Reputation: 0 (0%) |
daaamn. Guess i'll be considering a 3sgte for sure now. Always good to have an excuse i guess
Thanks for the info FAQ |
May 11, 2005 - 11:48 AM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
im still weary about this... my car has 184,000miles on it and the engine has about 100,thousand but i guess i'll try it in the oil, and gas tank...hmmm
could somebody locate the nearest vaccum line please? -------------------- |
May 11, 2005 - 3:47 PM |
In no way should you take my word as gospel, so just keep that in mind. and that exact same situation got me into my current ordeal w/ the 4agze. So dont be so quick to leap towards the fun / costly 3sgte solution, as its still a real pita to get done.
May 11, 2005 - 3:48 PM |
rod knock dosnt click. its more like a rattle sound that you should be able to hear when u pop the hood open and rev the motor. the rattle will get louder as you rev.
i think we all become car hypocondriacs after reading all this stuff on the net. youll read something about rod knock and the next minute you swear you have it! i could hear some ticking in my motor, and i thought, oh no, its the valves. then i used a stethiscope and found out that it was my injectors ticking (normal). take your car to 2 or 3 mecanics and see what they all say it is. -------------------- 15PSI - 30MPG - Megasquirt Tuned
May 11, 2005 - 5:00 PM |
Lago's,
Thanks i'll do that. My car sounds perfect when i rev the thing up its just that initial rev from idle, which i don't do anymore. But i never hear this click anymore as long as i don't hit the gas from idle. If it goes it goes |
May 11, 2005 - 7:38 PM |
Enthusiast Joined Sep 1, '04 From Ohio Currently Offline Reputation: 0 (0%) |
while we're talking about engine problems/smoke...my car burns oil. Like half a quart per full tank... i think it is the valve guides..anyone else have any ideas? would seafoam or any other fluid anyones used help me? (assuming it is valve guides)...it could also be piston rings, but i don't have much blowby, so i doubt it
May 11, 2005 - 8:02 PM |
check for leaks under the car...or oil anywhere on the motor.
May 13, 2005 - 7:32 PM |
there aren't any leaks...no drops on the floor, and the engine is clean...I know its burning oil, because it smokes...
May 23, 2005 - 7:04 PM |
I know this has been old for a bit, but I'd just like to add that I used this stuff and it works. Just another satisfide customer. I'm thinking about running it through again next time I change the oil, just to make sure I've got all the gunk out.
May 23, 2005 - 7:50 PM |
how long does the smoke last?
i dont want to get a ticket for driving around town while using this stuff. |
May 23, 2005 - 8:17 PM |
QUOTE(Hanyo @ May 23, 2005 - 8:50 PM) how long does the smoke last? i dont want to get a ticket for driving around town while using this stuff. [right][snapback]290783[/snapback][/right] It doesn't last that long. If you sit in your driveway for 10min, it'll go away enough that it won't bother anyone. And why would you get a ticket? What cop would do that? -------------------- Live Free, Be Happy
May 29, 2005 - 8:31 PM |
Enthusiast Joined Jul 16, '03 From Boise, Idaho Currently Offline Reputation: 0 (0%) |
just used it but it didnt smoke as much as you all said but it did a little bit and i also noticed a one second 0-60 difference and it just rained too
-------------------- My car = 0-60 in ~9sec
It's slow, I know |
Lo-Fi Version | Time is now: November 24th, 2024 - 1:12 AM |
