Engine electrical |
Engine electrical |
Mar 17, 2005 - 6:39 PM |
Enthusiast Joined Mar 17, '05 Currently Offline Reputation: 0 (0%) |
I just put a new starter on my current 94 celica st. Sometimes when I try to start it, it will just sounds like a clicking sound. Other times it completely shuts off all power to the car, no lights nothing. When I use jumper cables it starts right up. Does anyone have a clue what is wrong. Thanks
Mar 17, 2005 - 7:09 PM |
sounds like ur batt. is not hold enuff charge to kick up the starter.... if u have a multi-meter check ur batt. siff how much drain u have when u start the car.... How old is ur Batt. bythe way ?
Mar 17, 2005 - 8:22 PM |
I havent got a clue it came with the car when I bought it and the car hasnt really been driven. But I had the battery tested and it was fine at advance. I may try switching the battery out anyway, hopefully that will fix it. If that doesnt work Im having a new clutch put in next week so I can have them look at it too. I will grab a multi meter from work and test it with that. Thanks
Mar 17, 2005 - 8:32 PM |
is it cold where u are right now ? cause u might have a battery that doen't have right cold crank amps ..
Mar 17, 2005 - 8:34 PM |
Yeah its a lil cold here but its off and on between cold and warm. I guess its high possibility that its the battery so that's what I'll try thanks.
Mar 19, 2005 - 3:22 AM |
Enthusiast Joined Jul 21, '04 From Fresno, CA Currently Offline Reputation: 1 (100%) |
ive seen that happen before and it could be because of the starter line or the battery lines...too much corossion or its a little loose...
Mar 19, 2005 - 8:29 AM |
I will check everything again but thanks for the input....
Lo-Fi Version | Time is now: January 10th, 2025 - 3:47 AM |
