> PCV Valve Help, How do I remove it from the 5SFE?
post Mar 17, 2005 - 7:47 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
Well, my Celica finally turned 250,000 yesterday and I figure it's time to replace a few things. I've tried removing and checking the PCV valve before with no luck. It's a sticky little guy. Does anyone know if it twists in place or how I should pry it out? Here are the other things I'm planning to replace as I haven't touched them for the past 100k miles:
Plugs
Wires
Distributor cap
Rotor
Fuel filter
Any suggestions to add to the list would be much appreciated! I'm waiting for the summer and I'm going to get it repainted, too. Lot's of rock chips on the front end from Colorado driving...
-Mike
post Mar 17, 2005 - 7:50 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
i broke my pcv valve once. pretty sure you just have to pry or pull it out. such an annoying place for it.
post Mar 17, 2005 - 8:56 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
After it broke, were you able to pull it out easily enough? How about installing the new one? Thanks!
post Mar 18, 2005 - 12:22 AM
Jdog1385
Joined Apr 14, '03
yea when it broke i just pulled it out... its only plastic so its easy to break. putting the new one in was kind of a pain in the ass b/c of its location and you kind of have to bend it in. but you should have no problem doing it.
post Mar 18, 2005 - 11:06 AM
erics1one
Joined Aug 27, '04
From Orange County, CA
QUOTE(94GT @ Mar 17, 2005 - 5:47 PM)
-Mike
[right][snapback]258756[/snapback][/right]
Get a tiny flat head screw driver and lift the sides of the bottom ring. Then use a larger flat head, and lift the left and the right side evenly until the bottom half is out. You should be able to lift it out at this point.
post Mar 18, 2005 - 10:32 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
Thanks for the advice!
Lo-Fi Version Time is now: February 24th, 2025 - 10:30 AM
