2 Pages V  < 1 2
> more red in the interior *w/write up*, light around key
post Mar 23, 2005 - 6:13 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
just did mine in blue. had to file down the num74 led a little before it'd fit without deforming the socket too much for that to fit back into the transparent ring. the socket thing was sorta square-ish.
got the file out, laid it on the table, gripped the led in some plyers, then took a few long swipes down each of the 4 directions to...square-off-the circumference??
anyways, thanks again for the writeup. when i figure out how to work this digital camera i'll take some pics.
post Mar 24, 2005 - 1:41 AM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
Yeah i had the same prob with the 74 for the ignition. The ST does not come with a clear ignition light. I took the one off of the gt and put it on my st. changed the clock light. Heres some pics.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Mar 25, 2005 - 1:25 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
thanks for the pics Red. just got my blue gels in the mail today, so they'll be helping me out very soon!
post Apr 1, 2005 - 12:27 AM
CelicaRacer97
Joined Nov 29, '02
From Menifee CA
haha yeah this was one of the first things i had done to my celi when i first bought it in 97' i used red plastic tabs to change the ugly green color
post Apr 1, 2005 - 10:48 PM
juBz86
Joined Aug 18, '04
From NJ
http://www.6gc.net/photo.php?file=/images/...otos/2975_6.jpg
almost everything except for the radio. i kinda messed up the climate control.
post Apr 15, 2005 - 1:55 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
I'd love to do this, especially now that I've finally got directions (or at least somebody to harass) on changing the clock colour. Problem is, I just installed my 200W Alpine deck and specifically got a black face and green display to match the rest of the car. mad.gif
Oh well, at least I can fix the ignition light.
Instructions on changing the power window switch lights
This post has been edited by Galcobar: Apr 15, 2005 - 2:16 AM
post Apr 13, 2006 - 1:25 PM
b4dmunkey
Joined Apr 13, '06
From New Jersey, USA
i think im gunna put red leds under my dash so even my floors red too lol
post Apr 13, 2006 - 2:28 PM
ILuvMyCelica95
Joined Dec 16, '02
whats the size for the bulb around the ciggy lighter? i kinda smushed mine... lol
post Apr 13, 2006 - 2:36 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
the cig lighter is a strange toyota bulb with a huge base. i got a num74led and then smashed the hell out of the toyota bulb and then put the led in there. didn't even use solder, just bent it the right way. hasn't failed on me yet (about 1 year) though i might replace it with a soldered led+resistor series at a later date. the plastic ring is more translucent than transparent, and even the stock toyota bulb didn't light the ring very well.
post Mar 24, 2007 - 4:51 PM
very interesting post. I will see about doing a blue color, i have seen in a corolla 9th generation website how this guy used permanent marker and painted all his lights blue, even the stereo. Ill see how that one works, thanks...
post Mar 26, 2007 - 11:09 AM
Random_Stranger
Joined Mar 20, '07
From Bakersfield, CA
Thanks for the write up. I love what you did. Did you get the color gauges? Or did you get the red LEDs for it?
post Mar 26, 2007 - 11:13 AM
Random_Stranger
Joined Mar 20, '07
QUOTE(CelicaRacer97 @ Apr 1, 2005 - 5:27 AM) [snapback]264963[/snapback]
Hey, where do you get those colored tabs at? I need some red ones.
post Mar 26, 2007 - 12:12 PM
DSToyo
Joined Dec 16, '06
From Maryland
you know this thing is like two years old, right.
you can get plastic folder tabs at walmart, they work pretty well, i used them on my clock and ignition ring.
This post has been edited by DSToyo: Mar 26, 2007 - 12:13 PM
post Mar 26, 2007 - 2:05 PM
Random_Stranger
Joined Mar 20, '07
QUOTE(DSToyo @ Mar 26, 2007 - 5:12 PM) [snapback]539932[/snapback]
LOL I had no idea. Thanks man. I am a new person.
post Mar 27, 2007 - 5:49 PM
I broke the lighter bulb, how can i replace it, it sucks. By the way I am dipping my regular bulbs in blue paint for glass that i got in walmart for 2 bucks. Its a cheaper option.
what size LED is the clock, and the window controls.
What is the difference between wagner 194 and Sylvana 72 thye look the same. Which one should i use.
On another note, i have replaced the bulb for the bin on the passenger site, however it does not lght up, anyone has an exp. I dont think they will make a fuse just for this, since everythig else works fine. thanks...
This post has been edited by njccmd2002: Mar 27, 2007 - 6:00 PM
post Feb 10, 2009 - 6:51 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
Any one know what the light in the Cig. ring wouldn't be working? the bulb is still in one piece and appears to be fine
My Celica!
post Oct 2, 2009 - 9:13 PM
zfjohnson07
Joined Apr 11, '09
this is probably a dumb question but can you do a write up on how to change the gauges to glow gauges. just wanted to see how so when i get that far with my car i'll be prepared
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 23rd, 2025 - 4:57 PM
