Cooling, Oil and water temp |
Mar 21, 2005 - 12:24 AM |
Enthusiast Joined May 25, '04 From Columbus Ga Currently Offline Reputation: 0 (0%) |
I just changed me radiatior on my gt and it is much thicker now because it is the radiator with the auto tranny cooler on it. At first i was running prestone 50/50 mix in it and now i am running the Advance auto 50/50 crap and my car is getting much hotter. i noticed this when i ran my car on a dyno and put 150 to the ground when the oil was around 200 degrees and when it got up around 250 it it only put 120 to the ground. I read in the latest import tuner that optimum oil temp is between 200 and 220. I was wondering what all i could do to get the temp down. Does anyone have any suggestions?
Mar 21, 2005 - 12:31 AM |
150 whp on a 5sfe? What mods do you have?
As for your question, you can install an aftermarket oil cooler. Try newcelica.org. Many gts 7th gens get them. However, you shouldn't need one for the 5sfe. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Mar 22, 2005 - 1:14 AM |
all i have is intake and full exhaust. It suprised the crap out of me. I know that the gt's have a factory oil cooler but my oil is still going over 220 degrees.
Mar 22, 2005 - 1:28 AM |
Enthusiast Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
-------------------- All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Mar 22, 2005 - 10:54 AM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
Did the dyno shop have fans to direct air into the radiator? could be you are just stressing the cooling system if there is not enough airflow across the radiator.
Otherwise, you should run a full synthetic oil like Amsoil, its been known to reduce oil temps switching to full synthetic. |
Mar 22, 2005 - 10:59 AM |
Enthusiast Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
QUOTE(Drocay @ Mar 21, 2005 - 11:28 PM) [right][snapback]260530[/snapback][/right] I agree. 150 to the wheels 5sfe. Not possible. -------------------- Member of Team 5sfTe
Mar 28, 2005 - 12:37 AM |
150 is possible because I have a dyno sheet to prove it. It was when my oil was still cold and my entake wasnt sucking hot air from off the engine. Me and three other guys saw it.
The fan was blowing on the radiator but once it got hot all it did was loose power. I am trying to find a decent oil cooler and trying to get cooler air to my intake. I am also going to switch to synthetic oil. |
Mar 28, 2005 - 1:07 AM |
Enthusiast Joined Oct 4, '04 Currently Offline Reputation: 0 (0%) |
QUOTE(1995st204 @ Mar 28, 2005 - 5:37 AM) 150 is possible because I have a dyno sheet to prove it. It was when my oil was still cold and my entake wasnt sucking hot air from off the engine. Me and three other guys saw it. The fan was blowing on the radiator but once it got hot all it did was loose power. I am trying to find a decent oil cooler and trying to get cooler air to my intake. I am also going to switch to synthetic oil. [right][snapback]263030[/snapback][/right] Can you scan and post the dyno sheet for us skeptics? |
Mar 28, 2005 - 1:18 AM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
150 celica at our finger tips... what did i do buying an ST when i shoulda bought a GT , 40 more horse power *rolls eyes*
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Mar 29, 2005 - 8:58 AM |
QUOTE(1995st204 @ Mar 27, 2005 - 10:37 PM) 150 is possible because I have a dyno sheet to prove it. It was when my oil was still cold and my entake wasnt sucking hot air from off the engine. Me and three other guys saw it. The fan was blowing on the radiator but once it got hot all it did was loose power. I am trying to find a decent oil cooler and trying to get cooler air to my intake. I am also going to switch to synthetic oil. [right][snapback]263030[/snapback][/right] Please post a pic of your car on the dyno if you have one and lets see the dyno sheet. Sorry to seem like I dont believe you but Ive been around these boards for a VERY LONG time and no one yet has put down 150 to the wheels with even a highly modded 5sfe. As amatter of fact (if Manny would jump in here, HINT HINT ) with the #'s, your going to be running out of fuel before the 150 mark. -------------------- Member of Team 5sfTe
Lo-Fi Version | Time is now: November 29th, 2024 - 5:26 AM |
