> Oil filters good bad and ugly?
post Mar 21, 2005 - 5:14 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Well ive been running frams, being the fact they are easy to get your hands on. Recently I have been hearing these are horrible oil filters... whats a good brand? Ive heared amazing reviews of purolator filters but I cant find them anywhere! Does anyone know of a good online resaler for oil and filters?
post Mar 21, 2005 - 5:21 PM
I always use Toyota OEM filters...they're really good. I hear that Amsoil and Mobil 1 are even better though...I plan to make the switch to those if they're not too pricey.
post Mar 21, 2005 - 9:19 PM
Newbie
Joined Nov 3, '04
From Colorado
I use Mobil1 oil filter. I like it, because it seems to free up some horsepower.. But it could be just my mind playing tricks on me. I heard that castrol oil filters will put bad films on the engine internals though.. I used K&N filters before.. But I don't know which one to use on the 6GC's..
This post has been edited by Newbie: Mar 21, 2005 - 9:20 PM
post Mar 21, 2005 - 9:55 PM
QUOTE(Newbie @ Mar 21, 2005 - 9:19 PM)
[right][snapback]260432[/snapback][/right]
its in your head
if you really want to decide what filter to use, cut the used filter open and look inside... then put a mobil filter in and cut that open after you are done with it, then compare the 2.
post Mar 21, 2005 - 10:10 PM
boosted_K2
Joined Aug 30, '02
From Michigan
ive been using mobil products (10w-30 mobile 1 with the mobile 1 filter), but due to personal oiling issues and from alot of first hand accounts from other friends, im going to try switching it all over to amsoil after my next oil change.
No but I don't buy it
Cause I'm...
post Mar 21, 2005 - 10:39 PM
tomazws
Joined Oct 30, '04
From So Cal
What's bad about Fram? I use Fram too mainly because of that black grip.
post Mar 21, 2005 - 10:43 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
fram lacks the drain plug like other filters have. when you shut your car off the oil is suppose to stay in filter to keep some oil ready for start up. fram filters lack that and hard on engines because of it. "from what a mechanic told me"...he suggest purolaters or napa
post Mar 21, 2005 - 10:49 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
I'm not a believer of the hype. I bought my celica with 100,000 miles on it and I've put another 150k on it myself and all I've used are Frams. I just change them every 3,000.
post Mar 22, 2005 - 4:33 AM
soltrain
Joined Aug 19, '04
From Berkeley
walmart supertech filters are very good for the price. a lot of information is at the bobistheoilguy forums.
post Mar 22, 2005 - 8:22 AM
celicaboston1983
Joined Mar 20, '04
I use fram for the grip thingy and I also use Stp is that any good. Recently I'm using toyota filter
post Mar 22, 2005 - 7:52 PM
djspike
Joined Apr 23, '04
From WA
I use the TRD oil filter one from a toyota dealer
they work great no problems
post Mar 22, 2005 - 8:19 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
wut about K&N filters, there like 12 bucks but should be qualtiy.
Team 6gc 2005
post Mar 22, 2005 - 8:36 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
QUOTE(94GT @ Mar 21, 2005 - 10:49 PM)
[right][snapback]260459[/snapback][/right]
I have done the same.. not as mnay miles. But I have been useing Fram.. never had a problem with them. Also cant see spending $13 on a k&n one. I also change my oil every 2500 miles, cause i dont drive much. I think im going to try the mobil1 next time just cause thats the oil i tend to use.
post Mar 22, 2005 - 8:46 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
i use mobil 1 synthetic and i change every 5k just cause i should be able to get out of it that much condsider my car doesnt eat none of my oil, so the 12 bucks aint that bad.
Team 6gc 2005
post Mar 22, 2005 - 8:55 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
I too, like coomer use the toyota filters. They are often even cheaper then frams if you check out a few of your local dealers. I have seen them as cheap as $3.50.
It would be more efective to use 2 or 3 toyota or fram filters instead of one K&N. And yes you can change just the filter...
Also TRD oil filters are supost to be some of the best, but $20+ for an oil filter is insane unless your running a true "high performance machine"
post Mar 22, 2005 - 9:58 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Wix, its all about the Wix filters.
The best low priced filter there is.
DEF
I will return one day.
post Mar 23, 2005 - 12:25 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
yep fram are junk and wix are best bank for the buck napa filters are the same thing
post Mar 23, 2005 - 12:59 AM
how are you guys comparing whats better? has anyone here cut their filter open? the cheap ones i cut open are just carboard inside...
post Mar 24, 2005 - 4:41 AM
djspike
Joined Apr 23, '04
From WA
Well i get my TRD ones for 12 buxx at my local toyota dealer
i just have to wait a week for them to order it
post Mar 24, 2005 - 8:24 AM
Mr_E
Joined Nov 16, '04
From UK
I think I have a Blitz filter. Seems OK.
JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000
Needing another one 18000 miles later, bloody annoying.
Lo-Fi Version Time is now: January 9th, 2025 - 9:48 PM
