> Scion Xa and Starlet motors, Can they be swapped?
post Mar 22, 2005 - 8:48 AM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
K the first thing i dont wanna see is, "ANYTHING CAN BE DONE WITH MONEY" Yes we all know that. Sorry just had to throw that in there.
Anyway, now to the subject at hand. From what i know the Scion Xa is more of a Economical car made for high gas mileage and not very popular performance wise. The Starlet on the other hand is a mini beast, correct? A 1.6l turbo motor and light chassis. I think I've seen it in some kind of circuit/rally racing.
Well that being the case, what if someone were to blow their scion 1nz-fe motor and swap in a 4E-FTE startlet motor? How much work is this person looking at? Is it a simple drop in swap? What are the possibilites for this NEW TURBO SCION Xa TURBO
Soon to be boosting,
David
post Mar 22, 2005 - 10:27 AM
FallenHero
Joined Dec 26, '02
From Alabama
I'd personally swap in a different engine. the 4e is a waste in my opinion... too small.
post Mar 23, 2005 - 4:56 AM
ToYCeLi8
Joined Mar 6, '03
QUOTE(FallenHero @ Mar 22, 2005 - 8:27 AM)
[right][snapback]260627[/snapback][/right]
Well what else would fit? There isnt much room in that bay. I've seen it.
David
post Mar 23, 2005 - 11:43 AM
Einhander
Joined Oct 23, '03
From ky
If the 4e will fit i am guessing that maybe the 4age/gze could possibly be put in.
post Mar 23, 2005 - 12:18 PM
FallenHero
Joined Dec 26, '02
From Alabama
you would be surprised what will fit... 5th gen celica with a Lexus V8, 1st gen MR2 with a northstar motor...
I personally would re-build what is in there and boost it. If you really want to swap in something else, you must look at this from a few different dimensions. :1. where is your honor, 2. boost or no? 3. what power/life ratio do you want?
As far as honor, no toyota engine that is 1.6ish ltr will be able to outperform say a... B16 honda engine. The technology is far greater, and the overall design in superior. Ask kwanza, he has experiance working with honda and toyota engines. he will saay the same thing.
Turbo is best for most people. You want your right foot to make the car go fast. It happens to the best of us, and a turbo will install the biggest smile on your face.
3, Turbo or NA you will need to look at streetability. You can have 2-300 whp for a while or less than that for a Long time. On NA you can have 12-13:1 compression, but it is going to be a pain to maintain.
I personally would just install the stock motor re-built and be happy with a neet little slow car. wink.gif
post Mar 25, 2005 - 3:11 AM
ToYCeLi8
Joined Mar 6, '03
QUOTE(FallenHero @ Mar 23, 2005 - 10:18 AM)
[right][snapback]261234[/snapback][/right]
Engine was boosting *CUSTOM turbo kit* --> Engine blown--> Rebuild STARLET motor biggrin.gif --> being transplanted tongue.gif biggrin.gif tongue.gif tongue.gif biggrin.gif
David
post Mar 25, 2005 - 3:53 AM
FallenHero
Joined Dec 26, '02
From Alabama
post Mar 27, 2005 - 10:53 PM
biglipzit
Joined Dec 13, '04
From St. Lucia
The 4e-fte is a 1.3 turbo and not 1.6... And minibeast is exagerating alot since they run 16 second quartermile's stock. I have a friend which got the newer starlet glanza with the 4efte and boost increased to 12psi only gave a 15.92 sec quartermile. Average was 16.2 at 12psi... Don't forget it has an F head and is an economy engine and isnt meant for performance...
post Mar 27, 2005 - 10:57 PM
biglipzit
Joined Dec 13, '04
From St. Lucia
QUOTE(FallenHero @ Mar 23, 2005 - 12:18 PM)
Not from what i have seen on the quartermiles... toyotas black and silver top 4age's seem worthy adversaries to the hondas B16's and many cars with 20 valve swaps are more than capable of beating a civic type R stock for stock in the quartermile. The toyota vvt has come a long way and IMHO it stands up pretty well against the VTEC systems
post Mar 28, 2005 - 1:48 AM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(biglipzit @ Mar 27, 2005 - 8:57 PM)
[right][snapback]263008[/snapback][/right]
When discussing the 1.6ltr engine, I was speaking of the 4ag's. I have never talked to anyone with a black top, but people I have discussed the silvertop with, well, the majority, have been less than pleased with the power result. I was talking to Kwanza the other day about the way Honda's B-series head was designed Vs the 4ag 16v, and even the 20v. The B-series is just better. Granted, things can be done to both, but the honda design is superior.
I give credit where credit is due. In the 80's and early 90's Toyota had better engines than hondas... but that was over rather quickly.
Now that Toyota has brought over the 2zzge, there is a real competitor on the market as far as Na 4 cylinders go. however, Honda once again uped the anty with the 2.0's.
I will agree that toyota is the top competitor as far a performance Na 4's though.
post Mar 29, 2005 - 4:26 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(biglipzit @ Mar 28, 2005 - 3:57 AM)
I've built both, driven both, and raced both. The B16 just makes more power n/a and it can do it more effectively in a more streetable fashion. Just because you mention VVT, says you don't know much about VTEC or VVT... so we'll just leave that as is. VVT is NOT like Vtec. That's not to say the 20V can't hang... it can... but the Honda B series is KING of the n/a 4 bangers... soon to be overtaken by the K20's.
That being said... the Starlet 4EFTE (i've driven a paseo powered by this engine)... isn't all that. It has some decent potential because it has more rugged internals than a normal 4/5EFE... but it's still a small displacement economy motor. The stock turbo is small, the displacement small, it's just small. Overall, the turbo response doesn't feel much stronger than a normal 5EFE because the 5EFE has a really big stroke and has very good low-end response.
Lo-Fi Version Time is now: November 29th, 2024 - 3:36 AM
