Sidemarkers help, they dont work |
Mar 22, 2005 - 11:50 AM |
Enthusiast Joined Mar 17, '05 From Miami, Florida Currently Offline Reputation: 0 (0%) |
My old sidemarkers burnt out so i bought the clear ones to replace then. When i tried to turn them on they didn't work. Does anyone know if this is a problem with the wires or a fuse? Only the sidemarkers are being affected.
Mar 22, 2005 - 12:10 PM |
Enthusiast Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
I know this is a stupid question, but did you replace the bulbs? If not, then you check the fuse. Then you check the wiring plug right behind the sidemarkers, then it's a wiring issue if thats not it, and you've got a lot of wire to chase.
Changing the housing is just a superficial change, its not gonna make a burnt bulb or bad wiring suddenly better This post has been edited by shid: Mar 22, 2005 - 1:37 PM |
Mar 22, 2005 - 12:16 PM |
Yeah, those bulbs are probably the most common bulbs to burn out on sixth gen. Celicas...I'd check to make sure they're not burnt out.
Mar 22, 2005 - 5:02 PM |
the bulbs came with the sidemarkers and are brand new. im guessing its the wires that i have to check.
Mar 22, 2005 - 6:50 PM |
Yeah, then just to make sure you didn't unplug the wiring harness a couple inches away from the bulbs.
Lo-Fi Version | Time is now: November 27th, 2024 - 8:15 PM |
