Enthusiast ![]() ![]() Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) ![]() |
Before I flip through 30 pages full of search results, I know that the stock rims are 15 X 7 45 offsets.. Is the bolt pattern 5 X 100mm?
Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Newbie @ Mar 25, 2005 - 12:24 AM) Is the bolt pattern 5 X 100mm? Yes. ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
Yes. However, I believe the stock offset is either 38 or 40.
![]() Enthusiast ![]() Joined Nov 8, '02 From New Zealand Currently Offline Reputation: 0 (0%) ![]() |
As others have said, the stud pattern for the 6th gen celica is 5x100
Here's more info: Centre Bore: 54.06mm Lug Nut: 12x1.5 Offset: 35-38 (up to 43 max) -------------------- ![]() |
Lo-Fi Version | Time is now: February 20th, 2025 - 3:24 PM |
