> Will 7th Gen Big Brake Front Kit fit 6th ST
post Mar 26, 2005 - 2:30 PM
MonsterBOX
Joined Jan 8, '05
From Alabama
i have heard stock 7th gen rotors will fit the 6th gen gt in the front...will the 7th generation Brembo Big Brake Sport Kit fit the 6th generation st front?
post Mar 26, 2005 - 3:01 PM
ghostdog
From ny to philly
yes they should. I believe I even saw a member with them, but I can't remember who it was
post Mar 27, 2005 - 8:15 PM
FallenHero
Joined Dec 26, '02
From Alabama
I have heard the same thing. I wouldn't doubt it... The thing is, you would probably need a meaner master cylinder to properly take advantage of them. Also, if you have a ST that means you have drums in the back. i'd take care of that first. 2k in front brakes and 50's tech in the back doesn't match up.
I personally used the rear brakes off of a 5th gen GTS. I heard they had larger calipers, but i really doubt it. smile.gif The only sad thing is my front brakes are the same size as the back... as far as rotors at least, lol
post Mar 27, 2005 - 8:43 PM
orvillescelica
The 7th gen brakes are suppose to fit exactly. I havent seen anyone with them, so i dont know for sure, but this was found out by spedtoe169 so thats a pretty reliable source. the original thread is here:
http://www.6gc.net/forums/index.php?showtopic=8498&hl=
post Mar 30, 2005 - 7:42 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
QUOTE(FallenHero @ Mar 28, 2005 - 1:15 AM)
That's not always true.
I have an stock ST but all wheels have disk brakes. Maybe because I live in Europe?
post Mar 30, 2005 - 3:43 PM
Yeah, all sixth generation Celicas outside of North America got disc brakes all around, even the STs.
post Mar 30, 2005 - 4:17 PM
nik
Joined Sep 30, '02
ok i saw this on tv so....
they put 2 sets of front brakes kits on this car for the front and back brakes its a neat idea but expensive
so this is my thought gts oem front brakes with calipers in the back and new big brake kit in the front what do you think?
post Mar 30, 2005 - 5:53 PM
shin
Joined Aug 21, '04
From New York City
if that work... it'll definitely be sweet.
~*MuH NeW RiDe*~
post Mar 30, 2005 - 7:21 PM
What do you do about an e-brake if you do that? And the front brake setup is way different then the rear brake setup.
post Mar 30, 2005 - 9:18 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(nik @ Mar 30, 2005 - 9:17 PM)
[right][snapback]264202[/snapback][/right]
It only works on some cars. Basically they use a different caliper and rotor and a conversion like this will be 99% for looks. Oh yeah... you'll also lose the e-brake... =[
post Mar 31, 2005 - 4:20 AM
AndyST4
Joined Feb 3, '05
From Portland, OR
My cousin totalled his evo and the back calipers bolt up to our rear knuckles and they are bigger than our front brakes the only problem is the diameter of the rotor isn't big enough. the pad sticks off the endge of the rotor barely, so I need to either find some larger rotors that will work or find somewhere to have some made
post Mar 31, 2005 - 11:44 AM
nik
Joined Sep 30, '02
QUOTE(Kwanza26 @ Mar 30, 2005 - 7:18 PM)
[right][snapback]264406[/snapback][/right]
very true no e-brake but it would look really good probably more of a show car add on
post Apr 1, 2005 - 7:19 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
Thats pretty cool. But kind of worthless unless the rotor is bigger, correct? Would the evo rotor fit the car? What cars have the same size wheel spacing?
This post has been edited by Jeremy1210: Apr 1, 2005 - 7:19 PM
post Apr 2, 2005 - 7:43 PM
AndyST4
Joined Feb 3, '05
From Portland, OR
[right][snapback]265417[/snapback][/right]
[/quote]
Well it still works. I have the evo calipers on the back right now and they work well, the pad just barely hangs off, but I would rather find a little bigger rotors just to be safe
Lo-Fi Version Time is now: December 2nd, 2024 - 12:32 PM
