> is something wrong?, noises from 5sfe
post Mar 26, 2005 - 10:03 PM
duga10
Joined Jan 20, '05
sometimes when i turn my car on and leave it to warm up a little i hear a little "creeking" sound that seems to churn over and over until i actually press the throttle a little.
it almost sounds like the belt turning and turning, only the sound it makes is more like a squeeky door?
it doesnt matter if its cold or hot outside it still does it.
anybody had this problem before? or know what it is?
post Mar 27, 2005 - 2:05 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
tighten the belts, maybe?
post Mar 30, 2005 - 4:10 PM
cmorty
Joined Feb 22, '05
From Vegas Baby!!
Can you determine where the noise is coming from on the engine? I know that this sounds a little obscure. On my old 90 GTS, it had a 5SFE, and the waterpump went-out on it. But before it went-out, it was making a noise like the one you described.
I was told by a Toyota mechanic , that this is one of the tell-tale signs that your waterpump is about to go out. You usally have around a hundred miles before it craps-out. When the bearings start to wear-out around the lever, it'll start to make the noise. One of the benefits of having a mechanical than an electrical one I guess. wink.gif
This post has been edited by cmorty: Mar 30, 2005 - 4:11 PM
Lo-Fi Version Time is now: November 25th, 2024 - 12:23 AM
