![]() Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) ![]() |
http://www.everythingcelica.com/gal3/albums/inst/clocks1.jpg
http://www.everythingcelica.com/gal3/albums/inst/film.jpg http://www.everythingcelica.com/gal3/albums/inst/plug.jpg from everythingcelica.com most of us have the green clock, so only those will work with us. i would have never thought to use purple and blue to have a blue clock. guess ill have to try it out. This post has been edited by rocky2006: Mar 27, 2005 - 2:02 AM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 24, '02 From North Carolina Currently Offline Reputation: 1 (100%) ![]() |
what do they mean by "filters"......how do you change it??
oop, my bad:
http://www.everythingcelica.com/gal3/albums/inst/film.jpg (added this link to first post also) im guessing you just take out the stock lens and put the cellophane over the clock face and put the clock back in. This post has been edited by rocky2006: Mar 27, 2005 - 2:01 AM -------------------- ![]() |
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) ![]() |
where is the plug thats in the third pic? just the plug that plugs into the back of the clock?
i guess so. ill see if i can get to doing this today being easter and all.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) ![]() |
are clocks aren't that complicated, u just take it out pop the little brown thing off, if u leave it off your clock is now white, after that u can use either oracel transparent vynel like i did, or notebook tabs to change to what every u want.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
my click is teal with the filter off, which is why i put the guide up. if it was white then there would be no need for this topic.
it must change from model to model then i did mine on friday and it came out super good and real easy.
yeah mine is a light green/teal without the brown thing. I had a look at my clock plug just then and its different to whats in the pic. mine has 5 holes, but only has 4 wires (only 4 connections on the clock too). the green one is second from the left. would pulling the green still work?
and also, is there a way to remove the wire from the plug, without damaging it? theres some clips things on the top but i dont know how they work.. |
Enthusiast ![]() Joined Jun 18, '04 From Rio Grande Valley, TX Currently Offline Reputation: 0 (0%) ![]() |
I'm going to go try this right now. I'll give my show and tell later. Good luck to the rest of you dudes!
![]() -------------------- ![]() this is what happens when your little brother is better at photoshop than you are |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 18, '04 From Portland OR / Vancouver WA Currently Offline Reputation: 0 (0%) ![]() |
wow what is this...the 6th topic on changing the clock color? lol thats cool though Ill just add my .02 again hehe! Batman & I both used blue stage lighting gel (a thin film of plastic) on our clocks. I was lucky like some of the other people on here & had the super white clock once the lenz was removed...(the picture is w/ the film of course lol)
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) ![]() |
Its friggin easy just buy some celophane or tabs like i did and stick it in.
(yes that plug goes into the back of the clock) Might as well leave it hooked up since your lights are on when its dark and you dont need the super bright clock light in your eyes. clock...................................................... http://www.6gc.net/forums/index.php?showto...92entry261592 -------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Unfortunately I have the brown lens. This makes it kinda difficult because when you put in the filters it dims the light. I may need to disconnect that wire that dims it with the lights. Also, I haven't seen it during the day...I hope I can still see it.
I am gonna give it a try and disconnect my wire tomorrow. I will let you know what happens. KA-BOOM !!!!!!
blaque, you take the lens off. you dont keep it on when you change the clock color or the lens will dim it (like in your case) and make the color not be what you want.
i just did it. its much better than the teal i had. i ended up using 1 purple layer under 2 layers of blue. that seemed to have good lighting still and have a nice blue clock.
I just cut my wire. It works perfect. No more dimming. I am happy about this mod and it took about 2 min
![]() Enthusiast ![]() ![]() Joined Apr 23, '04 From WA Currently Offline Reputation: 3 (100%) ![]() |
Thanx Batman
just cut the green wire? does your plug look like the one in the pic (with 5 wires out the back, and the green in the middle)? my plug loks diff. it has only 4 wires out the back but 5 holes, and the green is 2nd from one end (not in the middle). :S
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) ![]() |
im probably gonna try this, hopefully I'll have the white clock ^_^
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
Lo-Fi Version | Time is now: April 23rd, 2025 - 5:47 PM |
