> Annoying squeaking problem., Might be my brakes?
post Mar 27, 2005 - 12:45 PM
gt_driFFter
Joined Nov 29, '04
Whenever I'm driving, I hear this high pitched, extremely annoying squeaking noise. I think it's coming from the passenger side. It squeaks faster as I accelerate too. I used to think it was a bad wheel bearing but then I realized that it stops whenever I apply the brakes. Any suggestions?
-Josh
post Mar 27, 2005 - 11:56 PM
gt_driFFter
Joined Nov 29, '04
Anyone? I want to try and fix this tomorrow so I need some advice on where to start.
-Josh
post Mar 28, 2005 - 1:00 AM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
take it to goodyear or somethin, my best advice, lol
To live, is to suffer
post Mar 28, 2005 - 1:25 AM
ghostdog
From ny to philly
a pad thats dislodged or something stuck between the pad and disc?
post Mar 28, 2005 - 8:15 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I havnt messed with my brakes yet, but when i had the same thing on my bimmer happen, it was a bent disc cover rubbing on the rotor. Best bet is, if your good with working on cars, take off the wheel its comign from and give a look see. Make sure nothing is rubbing on each other, check the break pads and such. if you then cant find a problem take it to a shop.
post Mar 30, 2005 - 7:12 PM
Shigexile
Joined Oct 30, '03
From IL
it could be the suspension. I have the same thing happeening to me too.
post Mar 31, 2005 - 10:31 PM
gt_driFFter
Joined Nov 29, '04
I really don't think it's the suspension because it goes away whenever I apply even the slightest pressure to the brakes. Digndoug, that sounds like it could be it. I will check my breaks this weekend.
Thanks again,
-Josh
post Apr 1, 2005 - 7:17 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
same thing happened to me. It was a stick that was stuck b/w my brake cover adn the rotor.
Lo-Fi Version Time is now: December 2nd, 2024 - 2:57 PM
