i got a problem!!, help |
Mar 27, 2005 - 9:44 PM |
Enthusiast Joined Jan 21, '05 From hanover, pennsylvania Currently Offline Reputation: 0 (0%) |
hey guys, i got a problem with my car. one of the pulleys on my car is shaking around like crazy and sound horrible. does anybody know if i need a new one or if it just needs tightened?? and how much it could cost for parts and labor?? thanks guys
Mar 27, 2005 - 10:08 PM |
Does the pulley wobble or is it just loose? If it wobbles, you probably need a new one(and maybe pump/compressor/whatever the pulley is on.) I had a bad power steering pump that wobbled just a bit on the pulley, and I shredded two belts before I finally fixed the problem by putting in another pump.
If it's loose, just try tightening it. Which pulley is it, and what kind of a sound does it make? -------------------- New Toyota project coming soon...
Mar 27, 2005 - 10:14 PM |
QUOTE(Coomer @ Mar 27, 2005 - 10:08 PM) Does the pulley wobble or is it just loose? If it wobbles, you probably need a new one(and maybe pump/compressor/whatever the pulley is on.) I had a bad power steering pump that wobbled just a bit on the pulley, and I shredded two belts before I finally fixed the problem by putting in another pump. If it's loose, just try tightening it. Which pulley is it, and what kind of a sound does it make? [right][snapback]262986[/snapback][/right] it wobbles, the pulley looks like it is connected to the water pump. i don't under stand how it could be the water pump though cuz i just got a new one put in sept. 2004 when i had my new engine put in. it sounds like a diesel truck when you start it and when you rev it a little bit. |
Lo-Fi Version | Time is now: November 28th, 2024 - 1:46 PM |
