short shifter installed, 7th gen - updated with pics |
Sep 5, 2006 - 8:23 PM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
ive been running my short shifter for a couple weeks with no issues. Its just an ebay 7th gen shifter. removing those rubber factory mounts made all the difference in the feel of the shifts. and i like the shorter shifter as well. no issues but i cut that one plastic tab everyone talked about while i was in there just incase.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Sep 7, 2006 - 11:10 AM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
TRD FTW still.
Remove complete stock assembly. Install complete TRD assembly. You set it, AND FORGET IT! It's like the Showtime Rotisserie. It may not be the shortest, but as many people know, the shorter the shifter/throw, is not always better... -------------------- |
Sep 7, 2006 - 12:59 PM |
Enthusiast Joined Sep 19, '05 Currently Offline Reputation: 3 (100%) |
It's more a matter of money.
Sep 7, 2006 - 5:17 PM |
Oh, and btw, thread is the same? So I can use a stock shift knob?
Sep 7, 2006 - 5:26 PM |
Enthusiast Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
yes you can.
Sep 8, 2006 - 8:11 AM |
What holds up your shift boot? Can you transfer the clip for it from the stock one?
Also, should I disconnect my negative battery terminal to do it, or am I not near anything airbag-related? This post has been edited by jess_i_74: Sep 8, 2006 - 8:11 AM -------------------- |
Sep 8, 2006 - 9:24 AM |
QUOTE(jess_i_74 @ Sep 8, 2006 - 8:11 AM) [snapback]477525[/snapback] What holds up your shift boot? Can you transfer the clip for it from the stock one? Also, should I disconnect my negative battery terminal to do it, or am I not near anything airbag-related? there is a small white perch on the shift arm that holds the shifter boot up. if you are installing a new arm, you will probably need to take it off the stock arm, and put it onto the new one. if it does not fit, you will either need to drill it out, or secure it in place some how if it is too big. i didn't see where anyone addressed that in this thread. as far as the (-) battery terminal, you shouldn't need to, unless you are disconnecting anything that involves the airbag ecu that is located under the center console. installing my entire TRD assembly, i did not have to remove this, so i don't see any reason why you should. if you are at all anxious about it, better safe than sorry. it takes at most 1 minute to pop the hood, remove the connection, and get back into the car. . -------------------- |
Sep 11, 2006 - 1:05 AM |
Enthusiast Joined Jun 16, '06 From Plantation, FL Currently Offline Reputation: 0 (0%) |
This will be my first big mod lol.
What exactly does it do? -------------------- |
Sep 11, 2006 - 11:48 AM |
Shortens the throw of your shifter.
Mine's on its way . . . -------------------- |
Sep 12, 2006 - 1:23 PM |
Enthusiast Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) |
yea i bought mine off of ebay for the 7th gen. it works fine however it wobbles... i'm curious if it was that little bolt clip like someone mentioned a few posts ago. i dont feel like taking it all apart to check lol. its a real easy mod i thought, it just took a wicked long time.
well worth your money -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- |
Sep 12, 2006 - 10:47 PM |
Enthusiast Joined Sep 29, '05 From Rochester, Massachusetts Currently Offline Reputation: 2 (100%) |
just finished me 7th gen short shifter swap. I am very happy with the results, i do need to grease it up some more, but she does feel one hell of a lot better than before. I dont know what you guys are tlaking about, i didnt have to cut any plastic piece and she feels fine.
you were just talking about the white piece that holds up the boot, mine was big for the new shifter so I had to wrap some electrical tape around the shaft to make it fit snuggly, other than that, about and hour and a half of work and it feels flawless. gr8 45$ mod! -------------------- The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed? |
Sep 15, 2006 - 6:41 PM |
Installing mine now, but have a question.
For the spring that centers the L-shaped piece, where do the two ends of it go? Does each end go around the little rubber stop in there? The shifter does not really want to center well anymore. Maybe that's why I have to cut that little plastic piece. -------------------- |
Sep 15, 2006 - 6:59 PM |
Nope, cut the plastic piece, still doesn't center. I have my spring in wrong somehow.
Sep 15, 2006 - 8:28 PM |
Ok, I got it done. Took me closer to two hours, because I ended up losing my clip and getting something I thought that would work from the hardware store, but didn't.
Anyways, I took a before-and-after from *exactly* the same location (resting on the center console): Easy cup removal with a cone wrench (from a set of bike tools): My bottom cup was a pain; it didn't go in until I put my entire weight on it. Also, I think it might be a bit oversized, since it doesn't fit down into the shifter cable connection quite as it should. Oh, and nothing holds up your shift boot. It stays up by itself since it is too long. You can't get the old white holder from the stock one off, as far as I can tell. It's a totally different animal to shift now; it is more notchy for sure, but I like the feel. It reminds me of an old buddy's Mustang. I keep thinking I'm not into reverse though because it doesn't go back far enough. This post has been edited by jess_i_74: Sep 15, 2006 - 8:36 PM -------------------- |
Sep 15, 2006 - 8:46 PM |
Enthusiast Joined Jun 27, '06 From South Lake Tahoe Currently Offline Reputation: 0 (0%) |
The Mod worked out very well. I am pleased with the cheap lil upgrade. You definitely have to remove those 4 rubbers mounts for it to install proper. Thanx for all the Pics and info all.
This post has been edited by SpoonR530: Sep 19, 2006 - 12:03 PM -------------------- |
Sep 19, 2006 - 11:21 PM |
Enthusiast Joined Aug 5, '06 From Maryland Currently Offline Reputation: 2 (100%) |
Awesome thread, although I am still confused over which is being used here. There seems to be two types on eBay, one with purple spacers, and one with silver.
Silver Another Silver Purple Spacers Which is good? |
Sep 20, 2006 - 9:15 AM |
People have used both, I believe. I got purple. it's not really the color of spacers, it's the fact that they are thicker than stock (which both are). I don't know that anyone has ever compared the two, but I think they are probably almost identical.
Oct 24, 2006 - 9:51 PM |
Enthusiast Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) |
QUOTE(jess_i_74 @ Sep 20, 2006 - 9:15 AM) [snapback]481770[/snapback] People have used both, I believe. I got purple. it's not really the color of spacers, it's the fact that they are thicker than stock (which both are). I don't know that anyone has ever compared the two, but I think they are probably almost identical. Any more thoughts on this? -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
Oct 25, 2006 - 6:11 PM |
Enthusiast Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
I got the silver one. Took me a while to realize I have to remove the rubber things in order to put in the silver legs.
I say this is a great mod if you don't lose your shift nob... I'm shifting with bare shift-stick. lol -------------------- |
Oct 26, 2006 - 1:19 PM |
Bought the Fidanza 7th gen short shifter. I also got an is300 shifter knob for it!
Lo-Fi Version | Time is now: November 23rd, 2024 - 6:50 AM |
