oil pressure sender switch, where is it? |
Mar 30, 2005 - 3:28 PM |
where on the 7afe is the OEM oil pressure sender switch located so i can hook up my oil pressure gauge
Mar 30, 2005 - 7:54 PM |
Enthusiast Joined Aug 29, '02 From San Diego CA Currently Offline Reputation: 0 (0%) |
under the alternator a little to the right on the block of the motor. ill post a pic if you need it.
Mar 31, 2005 - 12:15 AM |
ok i found it and put in the new presure gauge
but for sum reason its really not doing what it should the stock sensor (one wire) i cut off and spliced that wire with the gauge wire and hooked them up to the new sender switch then ran it to the gauge now the gauge worked for about 5 min while it was sitting in my drive way then when i started to drive it dropped the oil light (oem) on cluster? but its WAAAY full and i could feel any leaks when i stuck my hand down there? but i'll have to wait to see it in the morning to double check and make sure nothing is leaking does anyone know if i have to get a T- connection and use the stock sender switch in conjunction with the gauge? |
Mar 31, 2005 - 12:42 AM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
yes you do and i believe the thread is 1/8" bspt thread
Mar 31, 2005 - 10:33 AM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
here is a pic with a T fitting
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Mar 31, 2005 - 11:14 AM |
Enthusiast Joined Sep 23, '04 From fresno Currently Offline Reputation: 0 (0%) |
is it working now?? cauz i need it to install mine on my car also!!!!!!!!!
Mar 31, 2005 - 11:26 AM |
my oil pressure guage came with a pressure sending unit that i installed in my oil relocation kit along with a oil temp probe
do you guys have any pics of your stuff?? -------------------- yea your 3sgte is cool but ill stick to my 7agte
Mar 31, 2005 - 7:12 PM |
yea i used that pic yesterday
woot for thinking on my feet to use your HOW TO but i got the stuff from HD today i'll install it tomorrow afternoon |
Lo-Fi Version | Time is now: November 28th, 2024 - 9:39 PM |
