I'D HATE TO SOUND REDUNDANT.... |
Mar 30, 2005 - 6:03 PM |
Enthusiast Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
Hey 6gc! i have a question about my trunk...ive posted it already and got no answer so dont flame me about being redundant...i need help figuring out why my trunk wont open from the inside, i checked the rear to see if anythng was loose, but coulndt find anythng, i hear it clicking, but its not releasing. could someone help?
Mar 30, 2005 - 6:06 PM |
Enthusiast Joined Feb 16, '03 Currently Offline Reputation: 1 (100%) |
the trunk release cable is loose, remove the rear panel in ur trunk and make sure its on ... maybe your latch needs to be adjusted
Mar 30, 2005 - 6:07 PM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
bent trunk hinge?
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Mar 30, 2005 - 6:09 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
QUOTE(SoundSlut_dotcom @ Mar 30, 2005 - 4:06 PM) the trunk release cable is loose, remove the rear panel in ur trunk and make sure its on ... maybe your latch needs to be adjusted [right][snapback]264272[/snapback][/right] as sound said remove the cover look at the hatch assembly make sure your cable is in the right place -------------------- yea your 3sgte is cool but ill stick to my 7agte
Mar 30, 2005 - 6:12 PM |
Enthusiast Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) |
try this have someone try and lift the trunk while you pull the lever... i noticed h8d ce1ica's trunk does that...
-DMC |
Mar 30, 2005 - 6:13 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
So when you turn your key, and you pull up it doesn't open or do you hear it clicking when you use the level.
Mar 30, 2005 - 6:18 PM |
Enthusiast Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
I dunno where you posted your original topic but this belongs in exterior styling. if your other topic didn't get a reply simply bump it next time rather than posting another one
-gd |
Mar 30, 2005 - 10:17 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Make sure the trunk isn't locked if its locked it won't open from the inside.
Mar 31, 2005 - 1:04 AM |
how about this guys...
my hatch takes excessive force to close...like i gotta give it some acceleration to get it to close. if i do it normally it pops back up and i have to "open" it just so i can lift it to try and close it again -------------------- |
Mar 31, 2005 - 2:04 PM |
QUOTE(madmods @ Mar 30, 2005 - 6:13 PM) So when you turn your key, and you pull up it doesn't open or do you hear it clicking when you use the level. [right][snapback]264285[/snapback][/right] it feels a tiny bit loose, but i hear the connection in the back, it wont open, i will re-check it when it stops raining out here -------------------- |
Mar 31, 2005 - 2:05 PM |
O, and thanks ghost dog, didnt know if it belonged in exterior styling or not... thanks, will let u know what it was.
Lo-Fi Version | Time is now: November 23rd, 2024 - 9:18 AM |
