> how can I eliminate turbo lag
post Apr 7, 2003 - 6:32 PM
trdcelicagt
Joined Jan 29, '03
From colorado
how can i eliminate turbo lag
post Apr 7, 2003 - 7:18 PM
west_minist
Joined Oct 27, '02
From Barbados
It depends on alot of factors.
Please specify as much details as much as possible.
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post Apr 7, 2003 - 7:31 PM
forkee
Joined Nov 13, '02
From So Cal
post Apr 7, 2003 - 8:16 PM
0Re0
Joined Nov 13, '02
From Hawaii
That means you probably have a bigger turbo than you need. Large Turbo takes more time for the vanes to spool up (build RPM) before boost it actually produced. What you need is to go a smaller similar version than that. biggrin.gif
post Apr 7, 2003 - 8:59 PM
hiflytsi
Joined Jan 9, '03
From Concord, NC
or go twin style
post Apr 7, 2003 - 9:28 PM
Charlie97L
From North Bethesda, MD
QUOTE (trdcelicagt @ Apr 7, 2003 - 3:46 PM)
what setup are you running? 3sgtes barely have any lag at all. any small turbo will spool up almost instantly.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Apr 7, 2003 - 10:20 PM
Guest_Matthew_*
QUOTE (forkee @ Apr 7, 2003 - 4:45 PM)
lol
that's the most honest answer ever
post Apr 7, 2003 - 11:13 PM
FallenHero
Joined Dec 26, '02
From Alabama
If you give it to me, and forward this post to ten people or more, you will have good luck for ten days!
post Apr 9, 2003 - 9:39 AM
trdcelicagt
Joined Jan 29, '03
From colorado
i dont have a turbo yet i just orderd the 3sgte i shuld get it in a few weeks. i just wanted to know how to get ride of turbo lage when i get the engine
post Apr 9, 2003 - 10:07 AM
edo17982
Joined Dec 21, '02
From Italy
If the engine you're going to get is stock, you will not have turbo lag....You can expect it if you switch to a bigger turbo....
post Apr 9, 2003 - 3:05 PM
Charlie97L
QUOTE (trdcelicagt @ Apr 9, 2003 - 6:53 AM)
there is NO lag stock. only when you get up into the 400+ hp area, which costs a lot of $$, will you run into lag. serious upgrades will have to be done before it's an issue.
1994 Lexus ES300
1989 Supra Turbo
post Apr 9, 2003 - 4:39 PM
jontechie
Joined Oct 25, '02
From London- England
Go for a turbo with ceramic blades, it doesn't take as long
for the inertia to be overcome as with a steel bladed one, size is also a factor too
post Apr 9, 2003 - 4:47 PM
No0bOne
Joined Jan 5, '03
From Bay Area
Squeeze some juice for no lag.
Improve air flow(i.e airfilter/exhaust/dp/elbow/...etc). That's all i could think of right now.
post Apr 11, 2003 - 8:43 AM
jontechie
Joined Oct 25, '02
QUOTE (No0bOne @ Apr 9, 2003 - 2:01 PM)
Yeah gut the cat (apologies to any animal lovers out there)
post Apr 11, 2003 - 8:51 PM
west_minist
Joined Oct 27, '02
From Barbados
What you can also look at is the right Compressor to Turbine wheel size.
SportCompact Car Magazine had a very good issue on this topic.
Check out the June - August 2002 issue.
Try to get a turbo for a 2l engine or from a high power 1.8L car.
West_Minist
http://www.socob.bb
Lo-Fi Version Time is now: November 24th, 2024 - 4:47 PM
