Removing the cig. lighter assembly..., Grrrrr... pissin' me off. |
Apr 7, 2003 - 7:35 PM |
Enthusiast Joined Oct 16, '02 From Hohenwald, Tennessee Currently Offline Reputation: 1 (100%) |
I've tried and tried to pop out the cig. lighter assembly but I've had NO luck. Unplugging it was no problem but anything after that is hopeless for me. How do I get that thing out?!
Apr 7, 2003 - 9:07 PM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
you kinda got to turn it a little, and push from the back side. . give that a shot. see what ya come up w/.
-John- -------------------- |
Apr 7, 2003 - 9:58 PM |
Enthusiast Joined Dec 22, '02 From Missouri Currently Offline Reputation: 0 (0%) |
take a small flat head screwdriver ( i mean tiny) and pop it out. thats how i did it. It is a bitch to put back in though.
Apr 8, 2003 - 1:11 AM |
chainsaw
or just pull harder. duh |
Apr 8, 2003 - 2:49 AM |
ok from the back side you have to squeez twist and push and it comes right out
Apr 8, 2003 - 6:35 PM |
The chainsaw worked wonders. Thanks! This post has been edited by Delta_Phoenix: Apr 8, 2003 - 6:35 PM |
Apr 28, 2003 - 1:54 PM |
Enthusiast Joined Oct 30, '02 From Nebraska Currently Offline Reputation: 0 (0%) |
i tried to get mine out the other day and it just broke, so i said heck with it, im going to put a fuel pressure gauge in it prolly this week.
-------------------- 94 celica GT
90 Civic Si |
May 1, 2003 - 3:00 PM |
Enthusiast Joined Sep 22, '02 From Mammoth CA Currently Offline Reputation: 0 (0%) |
I just took mine out about 10 minutes ago...
ill post pics of what you need to do tonight |
May 1, 2003 - 8:56 PM |
Don't worry about it. This is an old thread, and I have gotten it out since I first posted
May 1, 2003 - 10:20 PM |
Enthusiast Joined Mar 6, '03 From South Central Los Angeles and Long Beach, CA Currently Offline Reputation: 1 (100%) |
I was wondering if i wanted to put some gauges where the cig. lighter and that little hole or power mirrors switch (depending on the model), like the water and/or fuel 2" autometer guages, without to many problems?
May 1, 2003 - 11:02 PM |
I wouldn't think it would be that difficult. I myself haven't installed any gauges. Probably all you would have to do aside from normal installation is cut or sand down the hole to a wider diameter to fit the gauge.
May 28, 2003 - 10:46 PM |
Enthusiast Joined Dec 16, '02 From IL Currently Offline Reputation: 0 (0%) |
Got a question. how do i tell, once i disconnect the cig lighter, which lead from the battery is positive(+) and which is negative(-)? i'm wiring a switch in to control a neon light and i have power spliced off the wires running into the back of the cigarette lighter. Only problem is, it won't work!
Lo-Fi Version | Time is now: November 29th, 2024 - 4:42 AM |
