27 Pages V  « < 5 6 7 8 9 > »
> my 5SFTE turbo project, 300+whp PG 23!!!!!!!
post Apr 13, 2007 - 3:14 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(shin @ Apr 13, 2007 - 8:45 AM) [snapback]546376[/snapback]
ya really need to teflon tape those. or ya be seeing oil leaks everywhere lol. manny had his over where the battery was and i had mine where the washer fluid tube is. that's a shorter route if ya don't have ABS.
what kit did you use for your relocation kit? I notice your profile says you used s summit kit.
post Apr 13, 2007 - 3:54 PM
he actually didnt buy the "kit" he just bought the 2 halfs they sell seperately, he got the type that just screws onto the block and has the two fittings sticking straight out.
it sucked.
didnt it, vin?
post Apr 13, 2007 - 4:16 PM
shin
Joined Aug 21, '04
From New York City
QUOTE(presure2 @ Apr 13, 2007 - 8:54 PM) [snapback]546485[/snapback]
it sucked.
didnt it, vin?
it realllllly did. should've bought the one you did lol. but hey.. someone gotta do the testing to know which works best. we learn from our mistakes lol.
~*MuH NeW RiDe*~
post Jun 12, 2007 - 4:48 PM
WOOOOOOOOOOOOOOOOOOOT.
wow, 2 years, 5sfte powered.
i totally forgot about the anniversary.
lol
ok so, here we are, 2 years later.
what have we learned?
5sfe + boost = good
just gotta build it right!
so, prolly the MOST asked question i get PM'd is:
do you have a parts list?
well, technicly, no.
i have a "basic" list, that every 5sfte owner should modify to fit theyre own needs, or plans. the idea is this:
think you see somthing you could make work better? DO IT! if we keep refining the setup, it WILL just keep getting better and more reliable.
ok so here we go:
the basics:
3sgte (gen 2) exhaust manifold
ct-26 twin entry turbo, (from a 90-93 celica alltrac, or 90+ mr2), with oil and water lines
stock 3sgte DP (or aftermarket)
3sgte (gen 2) oil pan, preferably from an alltrac, some of the mr2 ones have the oil level sensor, which will need to be blocked off = more work
at the MINIMUM, i would say 390cc injectors, i am currently running 460cc injectors from an rx-7, the part # is in my profile (just click the screenname wink.gif )
a decent front mount intercooler, (no, a stock alltrac, mr2, or DSM intercooler is not "decent") with associated piping, couplers and clamps
blow off valve of your choice
tuner toys head adapter fitting (for oil feed for turbo)
(2) -3an to 1/8npt STEEL male fitting to have welded to the stock oil feed line and for tuner toys fitting
~16-18" -3an stainless braided line (for oil feed)
oil filter relocation setup (kit or otherwise)
various rubber hose (for water lines for turbo) with clamps
SAFCII or emanage or whatever.
2 bar map sensor (alltrac 90-93 mr2T 90+)
im sure im missing some stuff, this was just off the top of my head.
anyway, to give you an idea,of how she's running,
this is a quick vid i threw together for jeff after this past weekends meet @ DWG.
this is with defgeph in the other lane, running ~14-15psi, IIRC (3sgteRC swapped)
post Jun 12, 2007 - 5:33 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
post Jun 12, 2007 - 8:01 PM
Valo666
Joined May 15, '05
From Toronto
dude..after riding in your car..im seriously wanting to turbo my car now...i think when i start workin in a months time im gonna start workin on buyin the parts for the build up. But seriously manny, your car is f*ckin quick. Its faster then my buddies Skyline GTS-T. But yea, manny, i think you have definatly sparked interest in alot of ppl to turbo their cars.
EDIT: Dont you also need a new MAP sensor to handel the extra pressure from the boost?
This post has been edited by Valo666: Jun 12, 2007 - 8:05 PM
post Jun 12, 2007 - 8:25 PM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
post Jun 12, 2007 - 9:59 PM
Vissi
Joined Jun 6, '06
From Cedar Hill ,Texas
happy anniversary, did yall exchange gifts?
0111011001101001011100110111001101101001
Chrome wont get ya home
post Jun 12, 2007 - 10:29 PM
QUOTE(Valo666 @ Jun 12, 2007 - 9:01 PM) [snapback]567807[/snapback]
yup, its all earlier in the beginning of the thread, and i forgot to add it to the list!!
vissi, the celica gives me the gift of boost every day.
post Jun 13, 2007 - 1:32 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(presure2 @ Jun 12, 2007 - 2:48 PM) [snapback]567758[/snapback]
lol
Congrats! I can't wait for my 5sfte! it sounds like it's soo much fun to drive!
ok so here we go:
the basics:
fuel pump
NGK BKR7 spark plugs
custom exhaust and muffler and such
gauges
oil restrictor to limit oil flow to turbo
Speaking of which, I'm kinda having a hard time finding some T's to tee into my coolant lines with. what did you use? also, does it matter which hose from the throttle body goes to which line to the turbo? (like is one a send and one a return that shouldn't be mix-matched?)
post Jun 13, 2007 - 2:28 AM
eggman40
Joined Aug 17, '04
From California
Congrats Manny! you Kick as s!
I had a few quick questions for you, I plan on getting water injection soon, and later go to ATS for their ct27 Turbo/ECU Tune combo... my goal being between 260-270whp. Is their kit worth it? i saw earlier in one of your posts that given a 2nd chance you woulda stayed with ct-26? I would get it dyno tuned as well....
or should i just rebuild my turbo and look for power elsewhere?
post Jun 13, 2007 - 5:22 AM
well when i said that, i just meant cost wise.
the ct-27 is expensive, and unless you have a GOOD core, gets even more expensive.
on a 3sgte, its a whole diffrent story.
gains are larger, cause it can untilize the extra air better.
good luck
post Jun 13, 2007 - 1:27 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(6strngs @ Jun 12, 2007 - 11:32 PM) [snapback]567923[/snapback]
post Jun 13, 2007 - 1:49 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Congrats Manny. 5sfte for life biggrin.gif well sorta, it will always have a warm place in my heart lol. you prove that if you buy good parts and dont skimp on a good turbo the 5sfte is mean machine, especially with that e-manage, instead of the primitive safc that everyone drooled over years ago. the whole 5sfte idea has definitely evolved.
post Jun 13, 2007 - 3:22 PM
shin
Joined Aug 21, '04
From New York City
QUOTE(6strngs @ Jun 13, 2007 - 6:27 PM) [snapback]568071[/snapback]
manny bought his Brass T's from Pep boys. i forgot the size though.. i'll have to look it up.
~*MuH NeW RiDe*~
post Jun 13, 2007 - 9:21 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(shin @ Jun 13, 2007 - 1:22 PM) [snapback]568146[/snapback]
I think the size is 3/8". I replaced one of those coolant hoses connecting to the throttle body and it was 3/8 and I put a piece of 3/8" hose over one of the turbo coolant lines and it fit.
post Jun 13, 2007 - 9:56 PM
QUOTE(6strngs @ Jun 13, 2007 - 10:21 PM) [snapback]568276[/snapback]
yea, iirc it was 3/8 hose.
vins right, i got the t's from pepboys.
post Jun 13, 2007 - 10:52 PM
eggman40
Joined Aug 17, '04
From California
post Jun 14, 2007 - 1:33 AM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(presure2 @ Jun 13, 2007 - 7:56 PM) [snapback]568291[/snapback]
hmm... at my local auto parts stores, I've seen plastic t's for vacuum lines, but not brass t's. I'll try to find some again I guess kindasad.gif
post Jun 14, 2007 - 9:34 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(6strngs @ Jun 14, 2007 - 2:33 AM) [snapback]568342[/snapback]
At my parts store (CAP) there are different drawers etc, and the brass ones are with the fuel fittings etc. maybe check there?
This post has been edited by jcbass7: Jun 14, 2007 - 9:35 AM
Lo-Fi Version Time is now: November 25th, 2024 - 1:32 AM
