my 5SFTE turbo project, 300+whp PG 23!!!!!!! |
Jun 8, 2008 - 9:42 AM |
Congrats bro.
Here's to 40,000 more! -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jun 8, 2008 - 11:25 AM |
congrats man! glad to so its still working out for you.
Jun 8, 2008 - 11:36 AM |
Enthusiast Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) |
very nice very nice! congrats!
-bboy -------------------- ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
Jun 8, 2008 - 12:10 PM |
Moderator Joined Oct 13, '06 From UK Currently Offline Reputation: 6 (100%) |
A superb example of how this should be done
Jun 9, 2008 - 1:44 PM |
Enthusiast Joined Mar 29, '06 From Regina, SK, Canada Currently Offline Reputation: 38 (100%) |
Great work Manny! Congratulations! Keep up the "Pioneering" and show us how to make it better!
Jun 9, 2008 - 4:10 PM |
Enthusiast Joined Dec 19, '07 From tx Currently Offline Reputation: 22 (100%) |
Badass man - I know you give alot of the other wouldbe 5S-FTE guys the courage to go ahead with it [now if only they'd listen to your "do it right" advice].
What scares me is how do you put on 40K in 3years? Must be more fun to drive than I thought -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Jun 9, 2008 - 4:58 PM |
Badass man - I know you give alot of the other wouldbe 5S-FTE guys the courage to go ahead with it [now if only they'd listen to your "do it right" advice]. What scares me is how do you put on 40K in 3years? Must be more fun to drive than I thought the wifey daily drives the car, all year round. that, plus all the other driving we do, packs on the miles pretty quick! -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Jun 9, 2008 - 7:41 PM |
Enthusiast Joined Jan 18, '07 From Bergen county NJ Currently Offline Reputation: 24 (100%) |
OOO I still say it will blow...hahaha awesome Manny...u r the KING in my book!!
Aug 4, 2008 - 10:22 AM |
hey guys, time for a little bit of an update, and a few notes to add.
first, a little backstory. i never really covered installing the turbo coolant lines, for 2 reasons. #1, when i originally installed the turbo setup, i wasnt quite sure exactly what i was gonna do, untill sunday morning, when just about everything was installed, partly because i had 2 different ideas on how i could do it. the first idea, was to just put T's into the throttle body coolant lines, like everyone had previously had done. the other, was to T into the oil cooler lines, because of how i had the oil filter relocated with the oil cooler over by the drivers headlight, not really mounted. i ended up going with the 2nd idea, running around between pep boys, and home depot for fittings and Ts to adapt the diffrent size lines together. it ended up being a pretty hacked up bunch of hose, and to "protect" it, i bought some "aluminum tape" that is normally made for duct work ect from home depot, and wrapped the lines that ran under and behind the turbo with it. it was crappy, to say the least, but it worked, and at the time i said to the wifey, "if it lasts a year, thats cool, i'll figure out somthing much better in the mean time, and we'll pull the turbo next year and rework it then." fast forward 3 years. LMAO. a couple weeks ago, the wifey pulls into the gas station right by the house, and notices a puddle under the car when she comes out. drives home, ( it didnt overheat at all) and notices it dripping under the car. i get home from work, see the 3ft round puddle under the car, and begin the inspection. it was pretty easy to tell it was coolant, and once i got under the hood, it looked to be coming from somewhere under the turbo (i recently installed a stock 3sgte heatsheild) so, i automaticly figured the coolant lines that i had made 3 yrs ago finally started leaking. hehe. we got the turbo off, and found the lines intact, but definetly seeping from the joints. a pic of the "frankenlines" from the coolant bypass lines on the block, to the relocated oil cooler.NOTE: this pic represents how NOT to do this..lol the white caps are where i tapped in for the turbo coolant lines. a close up of what happens after 3 years behind a super hot turbo (these lines were all wrapped with that home depot aluminum tape) not exactly bulletproof. so, i replaced those lines, with -10an rubber hose from summit, and bought some DEI heat sheild to go over them, and the oil lines i also removed the battery tray, and finally mounted the oil filter relocation where the overflow bottle was attached. you can kinda see the coolant lines in this pic. this time for the turbo coolant lines, i decided to eliminate the lines going to the throttle body, and use them to feed the turbo. i used 3/8" fuel hose, although i think somthing a tiny bit smaller would be better. (prolly ~9mm) the 2 lines that feed the throttle body come from 2 locations. one comes out the back of the waterneck on the drivers side of the motor, the other comes off the back of the coolant bypass lines, that run along the drivers side of the block here are 2 pics showing theyre locations: the waterneck outlet the bypass line location (under and behind the distributor, closer to the firewall) you'll have to kind of loop the hose around, so that it dont kink, and attach them to the turbo: once that was all set, i buttoned it all back up, and had jenn fire it back up, and lo and behold, it STILL leaked!!!!!!! turns out, for some reason, the front coolant jacket gasket (the one that just has a cover plate on it) decided to start leaking, and with the heatsheild in place, i couldnt see it coming out and running down under the turbo! a new gasket sealed it back up, and all it well again! -------------------- Former Team 5SFTE pro member ;)
Aug 4, 2008 - 10:32 AM |
QUOTE i buttoned it all back up, and had jenn fire it back up, and lo and behold, it STILL leaked!!!!!!! Haha you got to love that. Nice new lines. Those should last a long time. I also like where you put the oil filter. Makes me want to relocate mine. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Aug 4, 2008 - 10:51 AM |
Manny something is stuck in your turbo! you might wanna check that out.
Aug 4, 2008 - 11:27 AM |
Great work as usual and this should answer D-Man's questions alot better than I can by description. Question tho - when you say:
this time for the turbo coolant lines, i decided to eliminate the lines going to the throttle body, and use them to feed the turbo. Do you mean you no longer have coolant lines running to the TB or did I read that incorrectly? What exactly is the purpose of warming the TB by way of those lines anyway? I ask all this cause I'll be doing this on D-Man's car sometime later this year and the coolant source was the biggest PITA on my old setup [You think you got Frankenlines? I'm not even gonna describe mine - we will not be doing it that way for his car]. As usual, reading up on your setup so we can do his right the first time. -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 4, 2008 - 12:36 PM |
Do you mean you no longer have coolant lines running to the TB or did I read that incorrectly? What exactly is the purpose of warming the TB by way of those lines anyway? that is correct. The purpose of the lines running to the TB is to warm up the incoming air, especially during the winter. The downside is during the winter the car may idle a bit rich at first until fully warmed up. It's really not an issue if you turbo because you want cold air going in a all times. If you'ed want to do this on an n/a car I'd say don't waste your time, the gain would be useless. -------------------- |
Aug 4, 2008 - 1:14 PM |
Now I find myself wondering if we even need them 99% of the time here in Houston. It never truly gets cold here [Maybe 2-3days/year]. Cool this will definetely simplify things for his setup.
Thanks for the info guys and keep up the good work Presure. Edit: Ah hell - another question. What's that sticking out of the inlet to your turbo? Some kind of restrictor? This post has been edited by DEATH: Aug 4, 2008 - 1:18 PM -------------------- ENGINE: '93 RC 3S-GTE/WRC CT-20b [18-20PSI] PERF: TRD/HKS/ARP/NGK/MSD/ACT/Blitz/STRI/APEX'i/TwosRus/GReddy/Magnaflo/KOYO SUSP: Tein/Bilstein/SusTech/ INT: SS-III SEATS/Toyota Hyper Sports EXT: WRC/TRD/404 Its a safety feature so that people like you don't end up killing themselves or everyone around them. Slow down Paul Walker. 6GC Chat - Go there: [url="http://www.griffgirl.com/forum/chat/index.php[/url] |
Aug 4, 2008 - 2:30 PM |
Now I find myself wondering if we even need them 99% of the time here in Houston. It never truly gets cold here [Maybe 2-3days/year]. Cool this will definetely simplify things for his setup. Thanks for the info guys and keep up the good work Presure. Edit: Ah hell - another question. What's that sticking out of the inlet to your turbo? Some kind of restrictor? its just a rubber stopper to keep debris out. it came stuck in the TB of the 7a my cousin bought last year for his celica, and i kept it figuring it'd come in handy at some point. lol -------------------- Former Team 5SFTE pro member ;)
Aug 4, 2008 - 8:35 PM |
Enthusiast Joined Apr 22, '07 From Buckinghamshire, UK Currently Offline Reputation: 2 (100%) |
Do you mean you no longer have coolant lines running to the TB or did I read that incorrectly? What exactly is the purpose of warming the TB by way of those lines anyway? that is correct. The purpose of the lines running to the TB is to warm up the incoming air, especially during the winter. The downside is during the winter the car may idle a bit rich at first until fully warmed up. It's really not an issue if you turbo because you want cold air going in a all times. If you'ed want to do this on an n/a car I'd say don't waste your time, the gain would be useless. Yes, this is how i sourced the water for my T25. My TB is now heaterless. lol |
Sep 2, 2008 - 8:03 PM |
Enthusiast Joined Apr 16, '08 From CT Currently Offline Reputation: 0 (0%) |
would these work for the 5sfte LINK
Sep 2, 2008 - 9:14 PM |
Enthusiast Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) |
would these work for the 5sfte LINK technically yes. I used that downpipe and had no problems with it, but I hear that manifold and downpipe are very prone to cracking and not high quality. a stock 3s manifold is much stronger and still flows nicely. -------------------- 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Sep 2, 2008 - 9:18 PM |
x2 I had one and it work ok but it gets really ugly looking once it gets hot...and it is prone to cracks and such. I ended up switching to the stock 3sgte manifold.
Sep 3, 2008 - 1:44 PM |
which downpipe would you recommend?
Lo-Fi Version | Time is now: November 25th, 2024 - 3:37 AM |
