27 Pages V  « < 18 19 20 21 22 > »
> my 5SFTE turbo project, 300+whp PG 23!!!!!!!
post Apr 8, 2009 - 7:56 PM
damn.
what solution do you fill the parts washer with? any time i used one, it was always some oily stuff?
sorry, dumb question, i know.
post Apr 8, 2009 - 8:06 PM
supershannon77
Joined Jan 18, '07
From Bergen county NJ
that part washer is amazing manny and jenn....everything is looking awesome!!!!!!!!!!
facebook WRC st205
post Apr 9, 2009 - 12:39 PM
QUOTE (lagos @ Apr 8, 2009 - 7:56 PM) *
damn.
its a mix of "gunk" brand heavy duty parts washer solution, (2 gallons) and ~10gallons of kerosene.
thanks shannon!
head is on, i also did the valve seals while the head was off, (it helps that dustin had them laying around..lol) and as a side note ...a tranny drain/fill bolt fits perfectly in the hole in the head where the egr normally bolts on. wink.gif
pics later.
post Apr 9, 2009 - 4:51 PM
Nice !
post Apr 9, 2009 - 5:52 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
What about the port in the intake manifold? Are you just going to fab up a plate to block that port?
94 Celica gt white (sold)
post Apr 9, 2009 - 5:54 PM
QUOTE (bccentaur3 @ Apr 9, 2009 - 5:52 PM) *
post Apr 9, 2009 - 5:55 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Nice Manny!!
post Apr 10, 2009 - 4:37 PM
pics from yesterday
here is what i was talking about with the EGR stuff.
the tranny drain/fill bolt
close up
the union bolt that threads into the head
post Apr 11, 2009 - 11:33 AM
d0w0rkS0n
Joined Jun 10, '08
From Virginia beach
lookin really nice
1994 Toyota Celica ST Turbo
1991 Toyota MR2
MySpace
post Apr 12, 2009 - 4:47 PM
installed the oil and water pumps this morning, and got the cams back in, pics later.
a tip for those installing cams, with the motor in the car.
buy a set of feeler gauges with a angle on them, like this:
it makes it much easier to check the shim clearance on the exhaust cam.
i had a few shims that were out of spec, because i didnt properly check them when it was installed in the car.
with the angle of the motor, and the angle you have to insert the feeler gauge at, if your not carefull to be sure the feeler gauge is flat against the shim, you can easily get a false reading, that makes you think the shim is within spec, when in fact is can be still too small.
post Apr 13, 2009 - 5:52 AM
oil and water pump, cams and oil pan installed.
getting closer!!
post Apr 13, 2009 - 6:34 AM
jcaron9gt4
Joined Feb 26, '07
From Boston, MA
Break in period or will you be going straight to boost?
post Apr 13, 2009 - 7:54 AM
QUOTE (jcaron9gt4 @ Apr 13, 2009 - 6:34 AM) *
oh no, justin, it definetly needs a break in period, all new main bearings, and the need to seat the new rings require it.
ill be turning the boost controller all the way down, and going real easy on it for a couple thousand miles.
post Apr 14, 2009 - 7:43 AM
Red_T_swiftcam
Joined Dec 4, '08
From Minneapolis
hey Manny, would a 38mm wastegate block off plate fit to block the port in the intake manifold?
post Apr 14, 2009 - 7:52 AM
QUOTE (presure2 @ Apr 13, 2009 - 8:54 AM) *
Isn't there a debate MR2OC or other about this. Where some builders break in under full boost and some baby the hell outta it
post Apr 14, 2009 - 8:56 AM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Nice work Manny. Are you guys coming down to the Dragon?
Looks like a Harbor Freight parts washer, am I right? We have one biggrin.gif
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Apr 14, 2009 - 9:30 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
good start. id make a point about the fake Walboros out on Ebay too. make sure you are getting a genuine Walboro. because they look identical.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 14, 2009 - 10:12 AM
95st-celica
Joined Mar 29, '07
From Philly
looks good manny...as for the break in period...i wouldnt say a couple thousand...i think after a few hundreed or more you can start to turn the boost back up and get on it a little more...by 800-1000 miles everything should be pretty sound. great work so far though...i cant wait to see this thing in person
1988 Dodge Aries K (sold)
post Apr 14, 2009 - 12:23 PM
QUOTE (Red_T_swiftcam @ Apr 14, 2009 - 7:43 AM) *
maybe, idk.
yea, dan, some guys say to smash it hard from the get go, others say to baby it awhile.
naa, tweak, no dragon trip for us, especially with the baby.
yup, harbor frright had the parts washer on sale, it was a great deal for 80$.
Smaay Posted Today, 09:30 AM
huh?
lol
post Apr 14, 2009 - 12:39 PM
QUOTE (playr158 @ Apr 14, 2009 - 8:52 AM) *
There are a lot of really smart people on mr2oc, and a lot of really dumb ones. tongue.gif
I think the best rule to follow is the same guide lines the manufacture gives you when you buy a brand new car. Take it easy, avoid highways, and dont maintain a constant speed for an extended period of time for the first 1000 miles.
Lo-Fi Version Time is now: November 28th, 2024 - 7:31 PM
