27 Pages V  « < 23 24 25 26 27 >
> my 5SFTE turbo project, 300+whp PG 23!!!!!!!
post Jun 22, 2009 - 6:09 AM
QUOTE (_Jim_ @ Jun 22, 2009 - 6:01 AM) *
Very impressive results indeed. Manny where did your pump gas/street tune end up, and do you plan on using the map clamp settings for DD, or just on track days? Again, well done Manny. thumbsup.gif
it makes ~265whp @ 15.5psi for the street. (i gotta go edit my post on mr2oc, i posted it as 16.5psi there)
i wont run 19.5psi on the street everyday.
although...arts got me thinking...5gph nozzle....straight meth...hrmm wink.gif
post Jun 22, 2009 - 6:32 AM
_Jim_
Joined Sep 22, '08
From Bergenfield
VERY nice results Manny, car has to be a blast on the street. Picked up almost 30whp at same boost levels just with the addition of cams and bit more experience in tuning under your belt, cant beat that! GL WITH IT MAN!
330whp 309ft/lbs @ 21 PSI
post Jun 22, 2009 - 6:57 AM
here is the pump gas tune i had on it when i first got on the dyno:
once i cleaned up the lower RPM section, i gained ~30whp with only 1 more psi in the midrange.
post Jun 22, 2009 - 7:49 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
WOW!!!! 5s is getting up there!!! geez!!!! congratz on the number P
post Jun 22, 2009 - 8:18 AM
QUOTE (RUNNIN-LOW @ Jun 22, 2009 - 7:49 AM) *
thanks, man.
my next project has GOT to be getting that engine movement down to a minimum.
just look how much that damn motor shifts back and forth when i shift, its HORRIBLE.
i gotta get some mount inserts, and figure out some type of torque bar before i hit the track, all that engine movement just equals lots of wheelhop and spin.
here is basicly the 2 maps i will be driving on in the car.
street tune in blue, race tune in red.
post Jun 22, 2009 - 8:35 AM
RUNNIN-LOW
Joined Apr 4, '05
From ST PAUL, MN
gosh you are pushing SO much torque! the things a 5s can do....amazing! keep up the good work P.. sooner or later i know you will be pushing 350plus on stock 5s block.
post Jun 22, 2009 - 9:16 AM
QUOTE (presure2 @ Jun 22, 2009 - 7:09 AM) *
you could probably even try a 7gph one. im using a 5gph and didnt notice any negative side effects when i went from the 3 to the 5.
post Jun 22, 2009 - 9:37 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
does the engine movement show up on your dyno? sorry dont really know what a dyno should really look like
post Jun 23, 2009 - 5:40 AM
QUOTE (freddy121389 @ Jun 22, 2009 - 9:37 PM) *
no freddy, it dont. you can see it very well in this vid:
post Jun 28, 2009 - 10:09 PM
Johnnyny
Joined Apr 28, '09
From York pa
very inspiring post I am just starting to do my research and this will help when i swap my engine great stuff
post Jun 30, 2009 - 6:51 AM
macavely
Joined Nov 4, '02
Manny/Jenn... Seeing that vid and looking at those numbers brings a smile to my face.... and brings back good memories like when I was trying to catch up to when you had just installed the turbo, I still have all the pix you sent me when you where putting the kit together... damn what was that like 5 years ago ?? Now I'm just waiting for you to brake 350WHP
post Jun 30, 2009 - 6:56 AM
QUOTE (macavely @ Jun 30, 2009 - 6:51 AM) *
lmao, good to see ya still around man!
yea it was over 4 years ago now!
post Jun 30, 2009 - 7:16 AM
macavely
Joined Nov 4, '02
Yea I'm not going anywhere... lol.... I'm going to be getting the GT back from my mom and going full project car with her.. So I'll be around here a little bit more... but time really does go by fast. I ran into Corey a few months ago at one of my teams car meets. and we talked about how time just flys by ..
post Jun 30, 2009 - 7:29 AM
QUOTE (macavely @ Jun 30, 2009 - 7:16 AM) *
it certainly does, mac, it certainly does.
hard to believe my daughter is already 8 months old!
post Jun 30, 2009 - 7:35 AM
macavely
Joined Nov 4, '02
wow, how old is your old daughter now ? ... and when is the last time I was up there has it been a year already ??
post Jun 30, 2009 - 7:56 AM
QUOTE (macavely @ Jun 30, 2009 - 7:35 AM) *
yea, man, its been over a year since you've been up. time for a road trip! wink.gif
post Sep 16, 2009 - 10:49 AM
ravinaziankid
Joined Sep 11, '09
From NYC
Hey, this is a great write up..helped me prepare for this car I just picked up. But I just want to make sure I have the right idea for this oil feed line. I have the braided line already connected to the turbo, I have the end that's supposed to go into the head but it's not the right size to fit into the head, do I just need that fitting with -3 AN Male to 1/8 in. NPT Male? Like the part you listed from summitracing? http://www.summitracing.com/search/?keywor...03ERL&dds=1
The pic doesn't show the line very well with the 1/8 screw already in there, but it's not fitting into the head
Into this hole
I know this is an old thread, but hopefully someone can help too, I just wanted to be sure before I order the fitting. Thanks.
This post has been edited by ravinaziankid: Sep 16, 2009 - 1:36 PM
post Sep 16, 2009 - 10:59 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
NO NO NO!! The fitting needs to go where your oil pressure sensor is in the head. In the second pic, see the sensor screwed in on top of where you are trying to thread your fitting? Thats where the fitting needs to go. Something from tuner toys would work. Its a fitting you can screw the factory sensor and oil feed into.
O Manny, You should get some kind of torque damper and mount it on the top of the strut and then onto the alt bracket.
For example.
94 Celica gt white (sold)
post Sep 16, 2009 - 11:21 AM
enderswift
Joined Jul 12, '08
O.o ??? is that torque damper supposed to control engine movement? why is it better than getting polyurethane inserts for the mounts?
post Sep 16, 2009 - 11:36 AM
ravinaziankid
Joined Sep 11, '09
From NYC
QUOTE (bccentaur3 @ Sep 16, 2009 - 11:59 AM) *
For example.
OK, so it's supposed to go up there like how Pressure's pics are.
So does that hole I was trying to thread into on the bottom, is that supposed to be left open like that? Sorry, I'm very new to this. Thanks.
EDIT:
In this pic, where is that braided line going to?
This post has been edited by ravinaziankid: Sep 16, 2009 - 11:46 AM
Lo-Fi Version Time is now: November 24th, 2024 - 9:00 PM
